Re: Block fill questions
[Re: wyldebill]
#1708862
12/10/14 04:27 AM
12/10/14 04:27 AM
Posts: 2,933 Finalnd, Perkele
jyrki
Finalnd, Perkele
I wouldn't fill much over the bottom of the freeze plugs unless you are going to use an oil cooler. I had one that was filled close to the top of the freeze plugs, and the oil got very hot in continuous driving loosing its viscocity.
Plynouth VIP '67 TT IC EFI
[Re: Cab_Burge]
#1708864
12/10/14 11:28 AM
12/10/14 11:28 AM
NO advantage to a fill on street unit Save that $$ for fuel Just because it is in the magazines does not mean you should do it. No advantage --it is used to shore up thin castings and "bandaid" for stock blocks that will be stressed beyond common sense for a stock block---in these days of aftermarket blocks--their is just no reason to do it--got a thin cylinder in a race block you want to save?--OK Ground through the water in a SBC while stroker grinding? well then ok..but doing it because you think it will make a stock block stronger?? Forget about it--and main cap bolts are fine too , not much need for studs in most cases--save that Loot!
[Re: wyldebill]
#1708866
12/10/14 12:23 PM
12/10/14 12:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
i have not been a big fan of block filling. it seems to me that you would want the top of the cylinder the strongest, but your reinforce the bottem with concrete. thats why i am asking the question before i do it.
Actually the center of the cyl needs some help.. the top and bottom have the steel.. the top has the deck.. I have filled 2 blocks.. I cracked a cyl wall on one and water still ran into the cyl... that tells me that due to shrinkage it pulled back from the wall and thus it really didnt do anything except increase the temp of the water and the oil... specially on a street engine I wont fill it
[Re: FastmOp]
#1708874
12/10/14 03:50 PM
12/10/14 03:50 PM
Posts: 20,186 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I look at it this way. My 500 cubic inch engine lasted 275 passes running 8.60's- 9.0's. (440 block) In Pa weather that takes me 3 maybe 4 years before I finally cracked a block.( no fill, no girdle) It costs me about 400-500 dollars paid out to do prep work on a race block so that's cheap in my eyes. If you go fast enough with a stock block sooner or later its going to fail and I don't care what you do to it. Now I know some street guys are going to jump in and say but,but, but in my statement I said IF you go fast enough. Running 9.0's-10.0's with stock stroke, stock crank engines my cranks would have cracks in them every rebuild (3-4 years)but i never cracked a block. I got to the place where I would tear the engine down and not even check the crank for cracks. I would just throw it on the scrap pile. I broke one stock main cap before switching over to a set of 440source bilit caps. By the way the block that cracked never leaked a drop of water, ran a 8.62@155mph on its last pass, and the crack was found during Winter tear-down.
[Re: pittsburghracer]
#1708875
12/10/14 06:47 PM
12/10/14 06:47 PM
Posts: 7,506 Az
Crizila
Az
Bottom line ( IMO ) with block fill is temp control. If you can't control the oil and or water temp, the rest is a moot point - and you could very likely have problems on the street in this area, even with a 1/2 fill. Here is what a 3/4 fill looks like on a small block. Yes, the water still dose circulate.
Fastest 300
[Re: wyldebill]
#1708876
12/10/14 07:19 PM
12/10/14 07:19 PM
MR_P_BODY
Hey guys, I have a couple of questions about block filling. How high would you fill, for a 400 block? This will be driven as well as a race engine. Will be taking this on drag week. How will this affect water and, or oil temp?
One other thing about drag week... it always seems to be HOT.. seems common to be near a 100* and they tend to run you in some SLOW city traffic just to see how the cars can handle it... for my DW junker I didnt fill it .. it can get up to 210* running down the road at 75 for a hour or so.. if I back it down 5-10 mph it cools back to 180*
[Re: slippery440]
#1708878
12/10/14 09:27 PM
12/10/14 09:27 PM
MR_P_BODY
How many pounds will it take to the bottom of the soft plugs? HARD BLOK
If I remember right it was 1/2 of the bucket of hard block per side
[Re: MR_P_BODY]
#1708879
12/10/14 09:54 PM
12/10/14 09:54 PM
Posts: 774 Midland,Tx
wyldebill
Midland,Tx
i pulled the plug on filling the block. if you'll notice im from west Texas. so heat is always an issue. we're sonic checking the block this weekend. if i have a thin cylinder, then ill address it. cap walk is a bigger concern at this point, and i think we have it handled. thanks guys.
[Re: wyldebill]
#1708880
12/11/14 12:48 AM
12/11/14 12:48 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Bill, The 508 in the Barnyard Viper is a tall filled 440 (to the bottom of the water pump holes). It has completed two Drag Weeks. Water temp never gets over 190, oil temp usually 210-220. We have a small oil cooler on it, and it needs a bigger one, when we push it hard, oil temp climbs to 230-240, and pressure starts to drop, 10-15lbs less than normal, and we change the oil at the next track!
It was a race engine that got pressed into street duty, so far, so good.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
