4 speed Shifter for my R/T questions #1699156
11/15/14 01:46 AM
11/15/14 01:46 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Is there a way to identify the shifter by the numbels on it? Also mine has a grease zerk fitting on it, is that stock or something added.
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 4 speed Shifter for my R/T questions [Re: AZ_A12_BEE] #1699157
11/15/14 01:47 AM
11/15/14 01:47 AM
Dreaming of the 808
Dreaming of the 808
Close up
Re: 4 speed Shifter for my R/T questions [Re: AZ_A12_BEE] #1699158
11/15/14 03:34 AM
11/15/14 03:34 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Close up
What are the numbers at 9:00 relative to the zerk? Is that a model number or a date code?
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 4 speed Shifter for my R/T questions [Re: 69CoronetRT] #1699159
11/15/14 11:21 AM
11/15/14 11:21 AM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
I am not sure about this either, but I have the same shifter for one of my Coronet R/T's. I thought it was the wrong shifter for this application. I was going to call Wayne Brewer and ask him.
HEMI,S ARE FOREVER!!!
Re: 4 speed Shifter for my R/T questions [Re: AZ_A12_BEE] #1699160
11/15/14 12:17 PM
11/15/14 12:17 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Look on the reverse levers for a number. That will tell you the application from Brewers site.
Re: 4 speed Shifter for my R/T questions [Re: fastmark] #1699161
11/17/14 01:41 AM
11/17/14 01:41 AM
Dreaming of the 808
Dreaming of the 808
Thanks, I found 6353 stamped on the reverse lever so it's the correct shifter for my R/T. I found 0029 stamped on the body, I assume this is the assembly date of Jan 2nd 1969
Re: 4 speed Shifter for my R/T questions [Re: AZ_A12_BEE] #1699162
11/17/14 01:47 AM
11/17/14 01:47 AM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The zerk was added
Re: 4 speed Shifter for my R/T questions [Re: RoadRunnerJD] #1699163
11/17/14 02:11 AM
11/17/14 02:11 AM
fresno ca
mikeysmopars Offline
fresno ca
Handle is correct but box is 73 & up.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 4 speed Shifter for my R/T questions [Re: mikeysmopars] #1699164
11/17/14 12:09 PM
11/17/14 12:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The only thing 73 up that would use that box is A/F body ... I've also seen the zerk on pickup truck inland shifters ...
But as said it's not a musclecar era box.
Re: 4 speed Shifter for my R/T questions [Re: JohnRR] #1699165
11/17/14 12:20 PM
11/17/14 12:20 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
This box is identical to the 68-9 B Hurst box except for the grease fitting. Those were used in the later A/F cars and trucks/vans.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 4 speed Shifter for my R/T questions [Re: 64dodge572] #1699166
11/17/14 12:36 PM
11/17/14 12:36 PM
Los Altos Hills, CA
Dans 68 Offline
Dans 68  Offline
Los Altos Hills, CA
This box is identical to the 68-9 B Hurst box except for the grease fitting....
I'd pretty much agree. I'd always thought that the decoding went as thus:
2336= '64-'65 A & B Body
6353= '68-'69 B Body and '68-up A body
7174= '70 only B Body
7180= '70-'74 E Body and '71-up B Body
Dan
Re: 4 speed Shifter for my R/T questions [Re: Dans 68] #1699167
11/17/14 12:58 PM
11/17/14 12:58 PM
Dreaming of the 808
Dreaming of the 808
Dan
Do you think the zerk was added?
Re: 4 speed Shifter for my R/T questions [Re: 64dodge572] #1699168
11/17/14 01:00 PM
11/17/14 01:00 PM
Dreaming of the 808
Dreaming of the 808
Wayne, is the zerk something someone added?
Re: 4 speed Shifter for my R/T questions [Re: AZ_A12_BEE] #1699169
11/17/14 01:11 PM
11/17/14 01:11 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
No, it is factory install. Likely someone replaced a worn out box with a new one at some time.
FAX 937-947-4419
Re: 4 speed Shifter for my R/T questions [Re: 64dodge572] #1699170
11/17/14 02:44 PM
11/17/14 02:44 PM
Dreaming of the 808
Dreaming of the 808
Thanks, I plan on sending it to you for a rebuild
Re: 4 speed Shifter for my R/T questions [Re: 64dodge572] #1699171
11/17/14 09:40 PM
11/17/14 09:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I installed one of those boxes in my 69 Dart in place of the original ... it was an NOS I got off ebay, I had to adjust the reverse rod out a number of turns from factory install, like to the end of the rod. It worked ok, but the sweep of the arm on the one I had was different?
Re: 4 speed Shifter for my R/T questions [Re: JohnRR] #1699172
11/18/14 06:20 AM
11/18/14 06:20 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I got one of those from an 84 chevy pickup with a diesel, it had an MY6 transmission. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
