4 speed Shifter for my R/T questions
#1699156
11/15/14 01:46 AM
11/15/14 01:46 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Is there a way to identify the shifter by the numbels on it? Also mine has a grease zerk fitting on it, is that stock or something added.
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: 4 speed Shifter for my R/T questions
[Re: 69CoronetRT]
#1699159
11/15/14 11:21 AM
11/15/14 11:21 AM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
I am not sure about this either, but I have the same shifter for one of my Coronet R/T's. I thought it was the wrong shifter for this application. I was going to call Wayne Brewer and ask him.
HEMI,S ARE FOREVER!!!
[Re: mikeysmopars]
#1699164
11/17/14 12:09 PM
11/17/14 12:09 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Handle is correct but box is 73 & up.
The only thing 73 up that would use that box is A/F body ... I've also seen the zerk on pickup truck inland shifters ...
But as said it's not a musclecar era box.
[Re: JohnRR]
#1699165
11/17/14 12:20 PM
11/17/14 12:20 PM
Posts: 4,285 Ohio
64dodge572
Ohio
This box is identical to the 68-9 B Hurst box except for the grease fitting. Those were used in the later A/F cars and trucks/vans.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: 64dodge572]
#1699166
11/17/14 12:36 PM
11/17/14 12:36 PM
Posts: 166 Los Altos Hills, CA
Dans 68
Los Altos Hills, CA
This box is identical to the 68-9 B Hurst box except for the grease fitting....
I'd pretty much agree. I'd always thought that the decoding went as thus:
2336= '64-'65 A & B Body
6353= '68-'69 B Body and '68-up A body
7174= '70 only B Body
7180= '70-'74 E Body and '71-up B Body
Dan
[Re: AZ_A12_BEE]
#1699169
11/17/14 01:11 PM
11/17/14 01:11 PM
Posts: 4,285 Ohio
64dodge572
Ohio
No, it is factory install. Likely someone replaced a worn out box with a new one at some time.
[Re: 64dodge572]
#1699171
11/17/14 09:40 PM
11/17/14 09:40 PM
JohnRR
U.S.S.A.
I installed one of those boxes in my 69 Dart in place of the original ... it was an NOS I got off ebay, I had to adjust the reverse rod out a number of turns from factory install, like to the end of the rod. It worked ok, but the sweep of the arm on the one I had was different?
[Re: JohnRR]
#1699172
11/18/14 06:20 AM
11/18/14 06:20 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I got one of those from an 84 chevy pickup with a diesel, it had an MY6 transmission. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
