84 d150 wiring problem #1690532
10/25/14 10:37 PM
10/25/14 10:37 PM
Crockett ,TX
9
98RAM1500 Offline OP
Crockett ,TX
everything works except turn signals and the gauges, lights in the cluster work & lights work inside and out and it will turn the engine over but as far the gauges reading they don't in any of the positions & turn signals only work in accesories but won't in the on position & the blower motor won't work & yes it does work when directly to the battery, out of ideas on what it could be
Re: 84 d150 wiring problem [Re: 98RAM1500] #1690533
10/26/14 09:34 AM
10/26/14 09:34 AM
Crockett ,TX
9
Crockett ,TX
Checked all grounds they are good. Checked all the gauges before install they were good. Wiper motor only works in accessories as well only thing left to check is bulkhead connector
Re: 84 d150 wiring problem [Re: 98RAM1500] #1690534
10/26/14 09:48 AM
10/26/14 09:48 AM
Crockett ,TX
9
Crockett ,TX
What would keep the gauges from not reading at all & turn signals, wiper motor & blower motor not working in the on position?
Re: 84 d150 wiring problem [Re: 98RAM1500] #1690535
10/26/14 10:45 AM
10/26/14 10:45 AM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Sounds like ignition switch from here.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 84 d150 wiring problem [Re: 3hundred] #1690536
10/26/14 11:26 AM
10/26/14 11:26 AM
Crockett ,TX
9
Crockett ,TX
I was thinking that to but tried a old ignition switch out of another column & still the same thing what would be the chances of two bad switches one new & other old
Re: 84 d150 wiring problem [Re: 98RAM1500] #1690537
10/26/14 11:54 AM
10/26/14 11:54 AM
scratchnfotraction Offline
check the fuse box for the gauge fuse.
have a look at the fusable links and take the bulk head connection apart and check each wire connector.
I been chasing sorta the same problem on my 85..everything works till the headlights comes on then no rear brake/turn sigs. brake light are on though.
changed everything but headlight switch on mine.
that's next on the list.
Re: 84 d150 wiring problem [Re: scratchnfotraction] #1690538
10/26/14 02:07 PM
10/26/14 02:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The blower if it has power to the switch its probally the switch.I dont know how many I replaced in mine and customers trucks.Look at the amp gauge also.they do burn.The ign switchs were problems also.
Rocky
Chrysler Firepower
Re: 84 d150 wiring problem [Re: scratchnfotraction] #1690539
10/27/14 12:17 AM
10/27/14 12:17 AM
Crockett ,TX
9
Crockett ,TX
Now everything is working went ahead started the new engine & broke the can & lifters in & while it was idling I tried the turn signals and they work now and so do the gauges thank god
Re: 84 d150 wiring problem [Re: 98RAM1500] #1690540
10/27/14 12:44 PM
10/27/14 12:44 PM
Crockett ,TX
9
Crockett ,TX
It was the ignition switch but blower motor still doesn't work unless I hook it directly to battery
Re: 84 d150 wiring problem [Re: 98RAM1500] #1690541
10/27/14 01:13 PM
10/27/14 01:13 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Blower motor resistor is behind the glove box. Or it could be the master HVAC control switch. I can't recall the fan switch on any of my trucks ever going out.
Robert
'69 300 Convertible
'16 300 S Hemi
Re: 84 d150 wiring problem [Re: 3hundred] #1690542
10/27/14 02:15 PM
10/27/14 02:15 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
bet it's the dash switch, I've had a couple go bad. And anytime I'm in a boneyard, I always look inside a truck for a spare switch, and they are almost always already gone. Usually the high terminal melts off.Or the plastic mounts break.
1981 Dodge D150 360 auto
