84 d150 wiring problem
#1690532
10/25/14 10:37 PM
10/25/14 10:37 PM
Posts: 1,176 Crockett ,TX
98RAM1500
Crockett ,TX
everything works except turn signals and the gauges, lights in the cluster work & lights work inside and out and it will turn the engine over but as far the gauges reading they don't in any of the positions & turn signals only work in accesories but won't in the on position & the blower motor won't work & yes it does work when directly to the battery, out of ideas on what it could be
Re: 84 d150 wiring problem
[Re: 98RAM1500]
#1690533
10/26/14 09:34 AM
10/26/14 09:34 AM
98RAM1500
Crockett ,TX
Checked all grounds they are good. Checked all the gauges before install they were good. Wiper motor only works in accessories as well only thing left to check is bulkhead connector
[Re: 98RAM1500]
#1690534
10/26/14 09:48 AM
10/26/14 09:48 AM
98RAM1500
Crockett ,TX
What would keep the gauges from not reading at all & turn signals, wiper motor & blower motor not working in the on position?
[Re: 98RAM1500]
#1690535
10/26/14 10:45 AM
10/26/14 10:45 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Sounds like ignition switch from here.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: scratchnfotraction]
#1690538
10/26/14 02:07 PM
10/26/14 02:07 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
The blower if it has power to the switch its probally the switch.I dont know how many I replaced in mine and customers trucks.Look at the amp gauge also.they do burn.The ign switchs were problems also. Rocky
Chrysler Firepower
[Re: 3hundred]
#1690542
10/27/14 02:15 PM
10/27/14 02:15 PM
Posts: 7,833 east side of Ohio
basketcase
east side of Ohio
bet it's the dash switch, I've had a couple go bad. And anytime I'm in a boneyard, I always look inside a truck for a spare switch, and they are almost always already gone. Usually the high terminal melts off.Or the plastic mounts break.
1981 Dodge D150 360 auto
