70 440 cuts out on hard acceleration #1682530
10/06/14 12:17 AM
10/06/14 12:17 AM
S.florida
Jupiter331 Offline OP
S.florida
70 440 stock electronic ignition orange box. On hard acceleration engine shuts down as if I turned the key off. If I back off its fine. New distributor. Any help appreciated
Re: 70 440 cuts out on hard acceleration [Re: Jupiter331] #1682531
10/06/14 12:21 AM
10/06/14 12:21 AM
Kirkland, Washington
Pacnorthcuda Offline
Weak fuel pump
Re: 70 440 cuts out on hard acceleration [Re: Pacnorthcuda] #1682532
10/06/14 01:06 AM
10/06/14 01:06 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
yep , it is starving .
elect fuel pump near the tank will cure the problem .
i like the carter 4594.
no regulator needed.
place a on off switch under dash use for
Re: 70 440 cuts out on hard acceleration [Re: Jupiter331] #1682533
10/06/14 08:28 AM
10/06/14 08:28 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I'll ask something because it happened on my 70 440 as well.
Have you replaced the alternator recently? I swapped my stock alt to a Powermaster and on HARD acceleration I found the belt was pulling the alternator in and the post on the back was grounding on the cylinder head and shutting the car off.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: 70 440 cuts out on hard acceleration [Re: Jupiter331] #1682534
10/06/14 11:49 AM
10/06/14 11:49 AM
did it happen with the old dist & you replaced it & no change? does it cut out immediately when you floor it? or after several seconds & is this while cruising & you nail it or is from a stoplight? what speed/RPM. always done it or recent problem. what part changes/adjustments preceded it
Re: 70 440 cuts out on hard acceleration [Re: Jupiter331] #1682535
10/06/14 10:19 PM
10/06/14 10:19 PM
San Francisco
dilvoy Offline
dilvoy  Offline
San Francisco
I've had the same thing happen on vehicles with blocked fuel lines. One had the fuel pick up tube in the tank clogged with rust an the other was in the main fuel line running to the front of the car.
Re: 70 440 cuts out on hard acceleration [Re: Jupiter331] #1682536
10/07/14 12:26 AM
10/07/14 12:26 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
another one that bit me was too small / restricted air cleaner
