Re: 70 440 cuts out on hard acceleration
[Re: Pacnorthcuda]
#1682532
10/06/14 01:06 AM
10/06/14 01:06 AM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
yep , it is starving . elect fuel pump near the tank will cure the problem . i like the carter 4594. no regulator needed. place a on off switch under dash use for
[Re: Jupiter331]
#1682533
10/06/14 08:28 AM
10/06/14 08:28 AM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
I'll ask something because it happened on my 70 440 as well.
Have you replaced the alternator recently? I swapped my stock alt to a Powermaster and on HARD acceleration I found the belt was pulling the alternator in and the post on the back was grounding on the cylinder head and shutting the car off.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
