Vacuum pumps #1682295
10/05/14 03:02 PM
10/05/14 03:02 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Anybody run an aerospace components vac pump? How do you like it?
Also, does anyone use an oem smog pump to pull vacuum and how long do they last?
Yeah, it's got a smallblock.
Re: Vacuum pumps [Re: 340B5] #1682296
10/05/14 04:25 PM
10/05/14 04:25 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
My buddy has one he will sell you. He said it was junk. He has a GZ now and I have a three vane moroso.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Vacuum pumps [Re: 340B5] #1682297
10/05/14 07:00 PM
10/05/14 07:00 PM
AndyF Offline
AndyF  Offline
I have a four vane Moroso pump that I'm not using anymore. I switched to a dry sump so I do not need the vacuum pump.
Re: Vacuum pumps [Re: 1967dartgt] #1682298
10/05/14 11:16 PM
10/05/14 11:16 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Wafflebatter on here with the SBC Roadster has one..it works for him. I've heard the GZ is a nice piece.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Vacuum pumps [Re: 340B5] #1682299
10/06/14 01:46 AM
10/06/14 01:46 AM
One of the local racers was sold a Aerospace complete vacume system, it struggles to hold 12 inches at part throttle above 2500 RPM That is on a 572 C.I. World block Go with a Star or Moroso pump
Re: Vacuum pumps [Re: Cab_Burge] #1682300
10/06/14 12:59 PM
10/06/14 12:59 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I would be happy with 12 inches. I don't like those horror stories associated with 20 inches. And it's not like it's gonna make your car a whole lot faster.
2011 Drag Pak Challenger
Re: Vacuum pumps [Re: rickseeman] #1682301
10/06/14 02:16 PM
10/06/14 02:16 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Love my aerospace vacuum pump.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Vacuum pumps [Re: rickseeman] #1682302
10/06/14 07:01 PM
10/06/14 07:01 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I understand that at around 20" the pump can pull oil in suspension out of the crankcase causing lack of lubrication in some areas.
Re: Vacuum pumps [Re: slammedR/T] #1682303
10/06/14 07:02 PM
10/06/14 07:02 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
How long have you had that pump?
Re: Vacuum pumps [Re: 340B5] #1682304
10/06/14 10:19 PM
10/06/14 10:19 PM
slammedR/T Offline
slammedR/T  Offline
Over a year now, I bought the releif valve that goes on the pump, have a vacuum gauge in the othe valve cover, about 5-8 inches at idle and 12-15 WOT.
racemagnum
Re: Vacuum pumps [Re: 340B5] #1682305
10/07/14 10:16 AM
10/07/14 10:16 AM
an8sec70cuda Offline
I have an Aerospace vacuum pump and I do NOT recommend anyone else getting one. Mine pulls 6-8" at WOT and that's w/ the regulator maxed out.
My first one lost vacuum, rebuilt it, then it later destroyed itself (shaft seized). I got another one only b/c they cut me a good deal on a replacement and the cost to change to another brand of pump was real high at the time.
Aerospace's drive mandrel sucks too. No way to lock down the pullies good (just a little set screw) so they'll work loose, then they gall the shaft. When the pump locked up, it tweaked the shaft on the mandrel and caused a vibration.
I have a mandrel setup from CV products now...MUCH nicer and stronger.
When my current pump fails, I'll probably get one from GZ.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Vacuum pumps [Re: an8sec70cuda] #1682306
10/07/14 10:54 AM
10/07/14 10:54 AM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
We have a GZ on our engine but it gave Chuck a bit of a headache maybe he'll chime in.
Re: Vacuum pumps [Re: Wv68charger] #1682307
10/07/14 11:53 AM
10/07/14 11:53 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Over the years I've had nearly every kind on our engines. Areospace was probably the worse. GZ was certainly the best bang for the buck! Star or Morosso's Promod pump were the best
