Vacuum pumps
#1682295
10/05/14 03:02 PM
10/05/14 03:02 PM
Posts: 1,532 off the grid
340B5
off the grid
Anybody run an aerospace components vac pump? How do you like it?
Also, does anyone use an oem smog pump to pull vacuum and how long do they last?
Yeah, it's got a smallblock.
Re: Vacuum pumps
[Re: 340B5]
#1682296
10/05/14 04:25 PM
10/05/14 04:25 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
My buddy has one he will sell you. He said it was junk. He has a GZ now and I have a three vane moroso.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: Vacuum pumps
[Re: 1967dartgt]
#1682298
10/05/14 11:16 PM
10/05/14 11:16 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Wafflebatter on here with the SBC Roadster has one..it works for him. I've heard the GZ is a nice piece.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Vacuum pumps
[Re: Cab_Burge]
#1682300
10/06/14 12:59 PM
10/06/14 12:59 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I would be happy with 12 inches. I don't like those horror stories associated with 20 inches. And it's not like it's gonna make your car a whole lot faster.
2011 Drag Pak Challenger
Re: Vacuum pumps
[Re: 340B5]
#1682304
10/06/14 10:19 PM
10/06/14 10:19 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Love my aerospace vacuum pump.
How long have you had that pump?
Over a year now, I bought the releif valve that goes on the pump, have a vacuum gauge in the othe valve cover, about 5-8 inches at idle and 12-15 WOT.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: Vacuum pumps
[Re: 340B5]
#1682305
10/07/14 10:16 AM
10/07/14 10:16 AM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
I have an Aerospace vacuum pump and I do NOT recommend anyone else getting one. Mine pulls 6-8" at WOT and that's w/ the regulator maxed out. My first one lost vacuum, rebuilt it, then it later destroyed itself (shaft seized). I got another one only b/c they cut me a good deal on a replacement and the cost to change to another brand of pump was real high at the time. Aerospace's drive mandrel sucks too. No way to lock down the pullies good (just a little set screw) so they'll work loose, then they gall the shaft. When the pump locked up, it tweaked the shaft on the mandrel and caused a vibration. I have a mandrel setup from CV products now...MUCH nicer and stronger. When my current pump fails, I'll probably get one from GZ.
