Re: Stupid Question About 69 B Body Vent Window Assembly
[Re: parksr5]
#1637742
06/23/14 10:57 PM
06/23/14 10:57 PM
Its a support as there is a long rod with a threaded part and a nut that holds it secure to the lower part of the door frame. Prevents the vent window frame work from rattling / flexing when you hit a bump or shut the door. A lot of times the very small spot welds break off on the bracket.
[Re: wesgtx440]
#1637745
06/24/14 09:41 AM
06/24/14 09:41 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Here is a pic of the hardware
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: MOPARMIKE69]
#1637746
06/24/14 09:44 AM
06/24/14 09:44 AM
MOPARMIKE69
Nashville, TN
It is almost impossible to re weld the original welds and not interupt the window channel flow. I always re-weld them on the outside.
[Re: MOPARMIKE69]
#1637747
06/24/14 09:46 AM
06/24/14 09:46 AM
MOPARMIKE69
Nashville, TN
Here is a pic of the stud that slides into the bracket and as said it has a piece of foam to keep it from making noise.
[Re: MOPARMIKE69]
#1637748
06/24/14 10:31 AM
06/24/14 10:31 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Great idea...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: brianz426]
#1637751
03/17/15 05:00 PM
03/17/15 05:00 PM
Posts: 8,873 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
then force some J-B Weld in and clamp together. Do you guys think that would hold?
Personally I don't think so. I had the same problem, one broken weld. I threw a tack on the outside and also did the other bracket that wasn't broken. I don't ever want to take those things apart again !!
[Re: MOPARMIKE69]
#1637752
03/17/15 05:04 PM
03/17/15 05:04 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
Same here, been doing it that way for 20 years
From what I've seen, it's more like 75% are broke off
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: gtx6970]
#1637755
03/20/15 11:46 AM
03/20/15 11:46 AM
Posts: 8,160 DELAWARE
TONY_DAGOSTINO
DELAWARE
Hi Bill thanks for the mention yes we just recently got in the new vent window kits 68-70 B-body Chrome Vent Window Kit. Includes The Long Chrome Forward Post, Chrome Pivot Assembly, The Chrome Vent Window Channel And Lock Lever All For $545, We also have an installation guide for installing them, and we are working on the lower support brackets that are spot welded on They Are In Stock And Ready To Ship 302-398-0821 TONYSPARTS.COM Please call or email through our website
