Stupid Question About 69 B Body Vent Window Assembly #1637741
06/23/14 10:35 PM
06/23/14 10:35 PM
Oh
P
parksr5 Offline OP
parksr5  Offline OP
P
Oh
I've got a question about the vent window assembly for a 69 Road Runner/B body. If you look at the attached picture at the left at the very bottom of the channel for the door glass there is metal bracket that comes off of the channel that has a round hole. I've seen about 50% of the vent window assemblies that have this bracket and 50% that don't. What is it for? Is the piece just missing on some of the assemblies that I've seen or do some cars just not have them?
I'd appreciate if someone could clear this up for me. Thank you!
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: parksr5] #1637742
06/23/14 10:57 PM
06/23/14 10:57 PM
Its a support as there is a long rod with a threaded part and a nut that holds it secure to the lower part of the door frame. Prevents the vent window frame work from rattling / flexing when you hit a bump or shut the door. A lot of times the very small spot welds break off on the bracket.
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: ] #1637743
06/24/14 12:21 AM
06/24/14 12:21 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yes, if you look at the vent windows on my car you'll see that 50% have the bracket and 50% don't (one's broken off).
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: Stanton] #1637744
06/24/14 01:56 AM
06/24/14 01:56 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
It also has foam wrapped around the stud that attaches from the bottom of the door to keep it from rattling. And yes it is common for them to break and need re-attached to the vent frame.
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: wesgtx440] #1637745
06/24/14 09:41 AM
06/24/14 09:41 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Here is a pic of the hardware
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: MOPARMIKE69] #1637746
06/24/14 09:44 AM
06/24/14 09:44 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
It is almost impossible to re weld the original welds and not interupt the window channel flow. I always re-weld them on the outside.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: MOPARMIKE69] #1637747
06/24/14 09:46 AM
06/24/14 09:46 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Here is a pic of the stud that slides into the bracket and as said it has a piece of foam to keep it from making noise.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: MOPARMIKE69] #1637748
06/24/14 10:31 AM
06/24/14 10:31 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Great idea...
Troy
Houston Mopar Connection Club
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: hemi68charger] #1637749
06/24/14 08:02 PM
06/24/14 08:02 PM
Oh
P
parksr5 Offline OP
parksr5  Offline OP
P
Oh
Thanks for all of the help guys!
Great pictures Mike; that really helps!
I waxed the car this weekend and although I knew in the past, I really started noticing how bad some of the bright parts are on my car. The vent window frames are included in the bad parts. I've searched before for better vent window frames and wondered what the deal was with the brackets.
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: parksr5] #1637750
03/17/15 03:56 PM
03/17/15 03:56 PM
Maryland
brianz426 Offline
brianz426  Offline
Maryland
Rather than start a knew thread on this same subject I thought I would ask this question here since it wasn't brought up before. On both of my vent windows only one out of the two welds is broken. I was thinking that I could carefully pry apart the lower broken weld to gain some space in between the two pieces, then force some J-B Weld in and clamp together. Do you guys think that would hold?
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: brianz426] #1637751
03/17/15 05:00 PM
03/17/15 05:00 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Personally I don't think so. I had the same problem, one broken weld. I threw a tack on the outside and also did the other bracket that wasn't broken. I don't ever want to take those things apart again !!
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: MOPARMIKE69] #1637752
03/17/15 05:04 PM
03/17/15 05:04 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Same here, been doing it that way for 20 years
From what I've seen, it's more like 75% are broke off
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: Silver70] #1637753
03/18/15 03:28 PM
03/18/15 03:28 PM
Oh
P
parksr5 Offline OP
parksr5  Offline OP
P
Oh
I'm still looking for some nicer vent window assemblies; I'm hoping to find some at Charlisle this year. Since I started this post I have found and purchased a nos driver side remote mirror, nos grille and headlight bezels, re-chromed original tail light bezels, nos tail light lenses and I sent my front bumper off for chrome about a month ago. The car should look a lot better this year.
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: parksr5] #1637754
03/18/15 04:09 PM
03/18/15 04:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Tough to find nice originals.
Which is why - https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
Re: Stupid Question About 69 B Body Vent Window Assembly [Re: gtx6970] #1637755
03/20/15 11:46 AM
03/20/15 11:46 AM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
Hi Bill
thanks for the mention
yes we just recently got in the new vent window kits
68-70 B-body Chrome Vent Window Kit. Includes The Long Chrome Forward Post, Chrome Pivot Assembly, The Chrome Vent Window Channel And Lock Lever All For $545,
We also have an installation guide for installing them,
and we are working on the lower support brackets that are spot welded on
They Are In Stock And Ready To Ship
302-398-0821
TONYSPARTS.COM
Please call or email through our website
