Rather than start a knew thread on this same subject I thought I would ask this question here since it wasn't brought up before. On both of my vent windows only one out of the two welds is broken. I was thinking that I could carefully pry apart the lower broken weld to gain some space in between the two pieces, then force some J-B Weld in and clamp together. Do you guys think that would hold?
