Bouchillon AC install nightmare. HELP!
#1635082
06/18/14 12:09 AM
06/18/14 12:09 AM
Posts: 730 Nampa, ID
MadMatt
Nampa, ID
I'm installing a Bouchillon A/C kit and I've got a belt alignment issue that I can't seem to wrap my tired old brain around. The compressor drive belts are touching the driver’s side of the water pump and the front belt is touching the back of the fan pulley. I could possibly shim the fan pulley forward slightly, but I only have about 3/4” clearance between the fan clutch and the radiator. But that would still leave the issue of the belts touching the pump. The car is a 1970 Dodge Dart Swinger and was a factory A/C car. The A/C was intact and functional (until the compressor blew a front seal) and all the belts cleared just fine. Can anyone give me some guidance on how I might be able to resolve this? I'm going to post few pictures in case that helps.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Bouchillon AC install nightmare. HELP!
[Re: 62maxwgn]
#1635090
06/18/14 01:30 AM
06/18/14 01:30 AM
Posts: 4,730 Florida
BDW
Thats BB isn't it? I meant it only uses 1 belt on the double pulley AC and alternator part for SB. My VA setup has 3 total
[Re: BDW]
#1635095
06/18/14 01:55 AM
06/18/14 01:55 AM
BDW
The link I posted shows 2 belts total, 1 on AC/alternator, 1 on power steering. Am I missing something, your pic doesn't match the Bouchillon website pic for a SB setup.
[Re: BDW]
#1635096
06/18/14 02:11 AM
06/18/14 02:11 AM
MadMatt
Nampa, ID
Hmmm... I did see the photo before I ordered and thought I would end up with one belt. I looked that instructions again and what it says is "Alternator must have double groove pulley". But later it says "Belt routing is as follows: Drive belt for crank shaft and alternator installs on 2nd groove out and then around inner groove on AC compressor. The inner groove on crank shaft pulley and alternator are not used. The A/C compressor does not use the outer groove."
Now I'm really confused. Guess I'll try it that way, and see what happens.
[Re: MadMatt]
#1635098
06/18/14 08:55 AM
06/18/14 08:55 AM
Challenger 1
Cincinnati, Ohio
Doesn't the Bouchillon kit only use 1 belt. That was the reason I went with something else, don't like seeing the double pulleys with 1 slot open.
http://bouchillonperformance.com/inc/sdetail/467/572
2 belts on the small block. The instructions say it is mandatory.
I'd call JR at Bouchillon, he knows his stuff and helped me when I put there AC on both my cars.
My 340 only has one belt and I have been using it a lot for 10 years now. Still the same belt now that I think about it.
[Re: Commando1]
#1635100
06/18/14 09:26 AM
06/18/14 09:26 AM
Challenger 1
Cincinnati, Ohio
I'd call JR at Bouchillon......
STOP right there. That should have been the first reply.
It was in the first reply
