Bouchillon AC install nightmare. HELP! #1635082
06/18/14 12:09 AM
06/18/14 12:09 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I'm installing a Bouchillon A/C kit and I've got a belt alignment issue that I can't seem to wrap my tired old brain around. The compressor drive belts are touching the driver’s side of the water pump and the front belt is touching the back of the fan pulley. I could possibly shim the fan pulley forward slightly, but I only have about 3/4” clearance between the fan clutch and the radiator. But that would still leave the issue of the belts touching the pump.
The car is a 1970 Dodge Dart Swinger and was a factory A/C car. The A/C was intact and functional (until the compressor blew a front seal) and all the belts cleared just fine. Can anyone give me some guidance on how I might be able to resolve this? I'm going to post few pictures in case that helps.
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Bouchillon AC install nightmare. HELP! [Re: MadMatt] #1635083
06/18/14 12:10 AM
06/18/14 12:10 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Here's another...
Re: Bouchillon AC install nightmare. HELP! [Re: MadMatt] #1635084
06/18/14 12:11 AM
06/18/14 12:11 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Another...
Re: Bouchillon AC install nightmare. HELP! [Re: MadMatt] #1635085
06/18/14 12:12 AM
06/18/14 12:12 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Last one...
Re: Bouchillon AC install nightmare. HELP! [Re: MadMatt] #1635086
06/18/14 12:29 AM
06/18/14 12:29 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Just looking at it, it looks like you need a multi groove water pump pulley. Contact Bouchillon, they should be able to help. HTH, Steve
Re: Bouchillon AC install nightmare. HELP! [Re: Skeptic] #1635087
06/18/14 12:50 AM
06/18/14 12:50 AM
BDW Online content
BDW  Online Content
Doesn't the Bouchillon kit only use 1 belt. That was the reason I went with something else, don't like seeing the double pulleys with 1 slot open.
http://bouchillonperformance.com/inc/sdetail/467/572
Re: Bouchillon AC install nightmare. HELP! [Re: BDW] #1635088
06/18/14 01:28 AM
06/18/14 01:28 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Two belts here
Re: Bouchillon AC install nightmare. HELP! [Re: BDW] #1635089
06/18/14 01:30 AM
06/18/14 01:30 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Two belts here,no problem.
Re: Bouchillon AC install nightmare. HELP! [Re: 62maxwgn] #1635090
06/18/14 01:30 AM
06/18/14 01:30 AM
BDW Online content
BDW  Online Content
Thats BB isn't it?
I meant it only uses 1 belt on the double pulley AC and alternator part for SB.
My VA setup has 3 total
Re: Bouchillon AC install nightmare. HELP! [Re: BDW] #1635091
06/18/14 01:35 AM
06/18/14 01:35 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Two belts on the A/C and alternator,one on the water pump/power steering.
Re: Bouchillon AC install nightmare. HELP! [Re: BDW] #1635092
06/18/14 01:49 AM
06/18/14 01:49 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
2 belts on the small block. The instructions say it is mandatory.
Re: Bouchillon AC install nightmare. HELP! [Re: 62maxwgn] #1635093
06/18/14 01:49 AM
06/18/14 01:49 AM
BDW Online content
BDW  Online Content
2 belts total, you have 3?
Re: Bouchillon AC install nightmare. HELP! [Re: Skeptic] #1635094
06/18/14 01:51 AM
06/18/14 01:51 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
It would have to be a very deep, 3-groove, pulley. And it would make the belts considerably longer. I'm just surprised that everything fit with the stock set up, but doesn't work now.
Re: Bouchillon AC install nightmare. HELP! [Re: BDW] #1635095
06/18/14 01:55 AM
06/18/14 01:55 AM
BDW Online content
BDW  Online Content
The link I posted shows 2 belts total, 1 on AC/alternator, 1 on power steering.
Am I missing something, your pic doesn't match the Bouchillon website pic for a SB setup.
Re: Bouchillon AC install nightmare. HELP! [Re: BDW] #1635096
06/18/14 02:11 AM
06/18/14 02:11 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Hmmm... I did see the photo before I ordered and thought I would end up with one belt. I looked that instructions again and what it says is "Alternator must have double groove pulley". But later it says "Belt routing is as follows: Drive belt for crank shaft and alternator installs on 2nd groove out and then around inner groove on AC compressor. The inner groove on crank shaft pulley and alternator are not used. The A/C compressor does not use the outer groove."
Now I'm really confused. Guess I'll try it that way, and see what happens.
Re: Bouchillon AC install nightmare. HELP! [Re: MadMatt] #1635097
06/18/14 04:43 AM
06/18/14 04:43 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Comparing the bouchillon pic to yours it looks like the bracket from the cylinder head to compressor is on the wrong side of the ear on the compressor.
Re: Bouchillon AC install nightmare. HELP! [Re: MadMatt] #1635098
06/18/14 08:55 AM
06/18/14 08:55 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'd call JR at Bouchillon, he knows his stuff and helped me when I put there AC on both my cars.
My 340 only has one belt and I have been using it a lot for 10 years now. Still the same belt now that I think about it.
Re: Bouchillon AC install nightmare. HELP! [Re: Challenger 1] #1635099
06/18/14 09:16 AM
06/18/14 09:16 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I'd call JR at Bouchillon......
STOP right there.
That should have been the first reply.
Re: Bouchillon AC install nightmare. HELP! [Re: Commando1] #1635100
06/18/14 09:26 AM
06/18/14 09:26 AM
Cincinnati, Ohio
Cincinnati, Ohio
STOP right there.
It was in the first reply
Re: Bouchillon AC install nightmare. HELP! [Re: Challenger 1] #1635101
06/18/14 09:46 AM
06/18/14 09:46 AM
west palm beach, florida
modelmakerinc Offline
compressor looks to be too far forward, look at the mounting ears and make sure they are correct side of all the brackets.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
