Reverse rotation 360 #1629596
06/06/14 05:34 PM
06/06/14 05:34 PM
West Palm Beach, Florida
Copper Dart Offline OP
What needs to be done to use a marine reverse rotation 360 in a car?
Is it just change the cam shaft, oil pump, distributor and the drive gear?
Just the long block, no accessories.
Please tell me the crankshaft is the same
HELP
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Reverse rotation 360 [Re: Copper Dart] #1629597
06/06/14 05:38 PM
06/06/14 05:38 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Timing chain. (?) since it is a marine engine, is it a crank gear to cam gear set up?
Food for thought... Since it is a reverse rotation engine.
I also can see an oil pan.
Re: Reverse rotation 360 [Re: Rob C] #1629598
06/06/14 05:43 PM
06/06/14 05:43 PM
Still a standard timing chain but what is puzzling me is the dizzy drive gear is cut opposite of the small block I'm replacing it with.
Going to take pictures to post.
Mom.
Ricky Valdes
Re: Reverse rotation 360 [Re: Copper Dart] #1629599
06/06/14 05:53 PM
06/06/14 05:53 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
the knurling on the crank is backwards and will pump oil out the rear main seal.
Re: Reverse rotation 360 [Re: Copper Dart] #1629600
06/06/14 05:53 PM
06/06/14 05:53 PM
pic 1 old/bad engine
Mom.
Ricky Valdes
Re: Reverse rotation 360 [Re: Copper Dart] #1629601
06/06/14 05:54 PM
06/06/14 05:54 PM
pic 2 rebuilt/new engine
Mom.
Ricky Valdes
Re: Reverse rotation 360 [Re: Copper Dart] #1629602
06/06/14 05:57 PM
06/06/14 05:57 PM
pic 3 old on the left.
new and suspect marine on the right.
Mom.
Ricky Valdes
Re: Reverse rotation 360 [Re: Copper Dart] #1629603
06/06/14 06:00 PM
06/06/14 06:00 PM
pic 4
timing chain on the new suspect marine
Mom.
Ricky Valdes
Re: Reverse rotation 360 [Re: Copper Dart] #1629604
06/06/14 07:01 PM
06/06/14 07:01 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
hell I would run it as a reverse rotation! It will really freak people out when you nail the throttle and the right front picks up instead of the left front. But that is just me!
Back in the swing of things at Painless again! Great to be back!
Re: Reverse rotation 360 [Re: Copper Dart] #1629605
06/06/14 07:07 PM
06/06/14 07:07 PM
Q
Quicktree Offline
Quicktree  Offline
Q
HELP
what the heck are you trying to do?
Re: Reverse rotation 360 [Re: BJS racing] #1629606
06/06/14 07:34 PM
06/06/14 07:34 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
wouldn't it be the right rear
Re: Reverse rotation 360 [Re: BJS racing] #1629607
06/06/14 07:38 PM
06/06/14 07:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You would have to flip the rear axle over also, otherwise its got 3 speeds in reverse LOL
68 Barracuda Formula S 340
Re: Reverse rotation 360 [Re: Bad340fish] #1629608
06/06/14 11:00 PM
06/06/14 11:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
.....just thinking of the time a buddy and I did a "tune up" on his 302 Ford marine engine and it didn't run for a week....
Re: Reverse rotation 360 [Re: HotRodDave] #1629609
06/06/14 11:31 PM
06/06/14 11:31 PM
Hamilton,Ont
72chrgrally Offline
72chrgrally  Offline
Hamilton,Ont
We got burned on this with a 440 some years ago.
Photobucket sucks
Re: Reverse rotation 360 [Re: 72chrgrally] #1629610
06/07/14 12:59 AM
06/07/14 12:59 AM
my own world
theraif Offline
theraif  Offline
my own world
i know some dirt guys ran them
Re: Reverse rotation 360 [Re: theraif] #1629611
06/07/14 01:17 AM
06/07/14 01:17 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
i was given one and was told it had a steel crank, i did nothing with it and it was rusty i looked at the crank it look like a cast to me
Re: Reverse rotation 360 [Re: Quicktree] #1629612
06/07/14 02:35 AM
06/07/14 02:35 AM
HELP
I'm trying to use the long block to replace a hurt engine. The '74 360 is a fresh 30 over and decked. The heads were just done and resurfaced too. I started the job before I found out its a reverse rotation engine. What if I remove the rope seal and install a 2 piece lip seal? Would that help with the rear main sealing?
I have a full days labor into it already pulling, cleaning, prepping etc. I need to have this thing burning fuel by Monday.
Mom.
Ricky Valdes
Re: Reverse rotation 360 [Re: Copper Dart] #1629613
06/07/14 03:38 AM
06/07/14 03:38 AM
Q
Quicktree Offline
Quicktree  Offline
Q
HELP
yikes, good luck with that. better find a boat guy and sell it and move on I have a nice short block roller motor out of my challenger setting here
Re: Reverse rotation 360 [Re: HotRodDave] #1629614
06/07/14 11:12 AM
06/07/14 11:12 AM
Lehigh Acres, Florida
rickstershemi Offline
Not sure on a 360 Mope, but I did a 350 GM out of my old Cruiser for a project I did and just had to use the correct rear main seal....cam and dizzy....problem solved...???
Rickster
Re: Reverse rotation 360 [Re: Quicktree] #1629615
06/07/14 11:16 AM
06/07/14 11:16 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Is the crank OK in the "hurt" engine? Too bad you aren't closer, I've got a crank you could have.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
