Reverse rotation 360
#1629596
06/06/14 05:34 PM
06/06/14 05:34 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
What needs to be done to use a marine reverse rotation 360 in a car? Is it just change the cam shaft, oil pump, distributor and the drive gear? Just the long block, no accessories. Please tell me the crankshaft is the same HELP
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: Reverse rotation 360
[Re: Rob C]
#1629598
06/06/14 05:43 PM
06/06/14 05:43 PM
Copper Dart
Still a standard timing chain but what is puzzling me is the dizzy drive gear is cut opposite of the small block I'm replacing it with. Going to take pictures to post.
[Re: Copper Dart]
#1629599
06/06/14 05:53 PM
06/06/14 05:53 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
the knurling on the crank is backwards and will pump oil out the rear main seal.
[Re: Copper Dart]
#1629602
06/06/14 05:57 PM
06/06/14 05:57 PM
Copper Dart
pic 3 old on the left. new and suspect marine on the right.
[Re: Copper Dart]
#1629605
06/06/14 07:07 PM
06/06/14 07:07 PM
Quicktree
HELP
what the heck are you trying to do?
[Re: BJS racing]
#1629606
06/06/14 07:34 PM
06/06/14 07:34 PM
Posts: 2,495 Oregon City, OR
Baxter61
Oregon City, OR
hell I would run it as a reverse rotation! It will really freak people out when you nail the throttle and the right front picks up instead of the left front. But that is just me!
wouldn't it be the right rear
[Re: Quicktree]
#1629612
06/07/14 02:35 AM
06/07/14 02:35 AM
Copper Dart
HELP
I'm trying to use the long block to replace a hurt engine. The '74 360 is a fresh 30 over and decked. The heads were just done and resurfaced too. I started the job before I found out its a reverse rotation engine. What if I remove the rope seal and install a 2 piece lip seal? Would that help with the rear main sealing? I have a full days labor into it already pulling, cleaning, prepping etc. I need to have this thing burning fuel by Monday.
[Re: Copper Dart]
#1629613
06/07/14 03:38 AM
06/07/14 03:38 AM
Quicktree
HELP
yikes, good luck with that. better find a boat guy and sell it and move on I have a nice short block roller motor out of my challenger setting here
[Re: HotRodDave]
#1629614
06/07/14 11:12 AM
06/07/14 11:12 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Not sure on a 360 Mope, but I did a 350 GM out of my old Cruiser for a project I did and just had to use the correct rear main seal....cam and dizzy....problem solved...???
Rickster
[Re: Quicktree]
#1629615
06/07/14 11:16 AM
06/07/14 11:16 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Is the crank OK in the "hurt" engine? Too bad you aren't closer, I've got a crank you could have.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
