Re: X pipe and mufflers. What do you run?
[Re: JohnRR]
#1589856
03/12/14 04:58 PM
03/12/14 04:58 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
I saw that before somewhere
Isn't your brother responsible for that abortion of a pipe ?
Im probably shouldn't waste my fingers typing a response , but its easy for the ignorant to use derogatory terms to make fun of something . John , put the "O" pipe on a dyno up against any and all of the others that are out there and then come and belittle it .
[Re: Kern Dog]
#1589857
03/12/14 06:10 PM
03/12/14 06:10 PM
Posts: 8,398 Highland, MI.
Sunroofcuda
Highland, MI.
So I have to axe you guys - WHY do you run X-pipes?
[Re: mopar_man]
#1589861
03/12/14 09:52 PM
03/12/14 09:52 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
I love that "sort of a X-pipe" as it has given me countless fun stories of how it came to be. I ran it on my roadrunner for awhile and it seemed to work fine and always was fun to have people who needed to look under the car ask about it.
What the heck maybe I will put it back on for Spring Fling??
[Re: mopar_man]
#1589862
03/12/14 09:57 PM
03/12/14 09:57 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
Must have been a well kept secret as not many people knew anything about what happens in front of a converter. BTw did they have converters in 74 ?
I happens in the entire exhaust system, not a function of the converter.
[Re: Kern Dog]
#1589866
03/14/14 08:56 PM
03/14/14 08:56 PM
RapidRobert
OT My next one I am going to incorporate 2 of those "mesh" connectors, 1 on each side that flex to help with ex system rattling & less stress on the header pri pipes/welds from the eng vibration/movement
[Re: dynorad]
#1589869
03/17/14 02:12 PM
03/17/14 02:12 PM
Posts: 252 Seattle, WA.
edp
Seattle, WA.
Here is a shot of my custom x pipe. I built it based on an article I found on the net that said that there is power to be found in a larger crossover area.
hows it work? I'm having duals installed right now with an X pipe but not like that I'm sure.
And since we're on exhaust, what is the difference between "HP / Magnum, Rams horn" manifolds for the 383 / 440 and stock ones?
Is it 2.5" vs. 2.25" ??
[Re: edp]
#1589871
03/17/14 04:59 PM
03/17/14 04:59 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
That and they should flow better .
[Re: dynorad]
#1589872
03/18/14 01:09 AM
03/18/14 01:09 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Quite interesting. Thanks for the article too.
[Re: BSB67]
#1589875
03/23/14 09:38 PM
03/23/14 09:38 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Is that what is refered to as reversion ??? Is'nt that why they "step" areas {smaller into a bigger port} like intake manifolds, head exhaust ports into bigger header primaries etc ?? Giving more resistance to the backflow pulses....
Glad to hear you've got the X pipe up and running... I used the TTI 3 inch H pipe for the GV unit and don't really mind the tone from it... I would'nt say it has a drone like some systems I've heard..
