Page 2 of 3 1 2 3
Re: X pipe and mufflers. What do you run? [Re: JohnRR] #1589856
03/12/14 04:58 PM
03/12/14 04:58 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
I saw that before somewhere
Isn't your brother responsible for that abortion of a pipe ?
Im probably shouldn't waste my fingers typing a response , but its easy for the ignorant to use derogatory terms to make fun of something . John , put the "O" pipe on a dyno up against any and all of the others that are out there and then come and belittle it .
Re: X pipe and mufflers. What do you run? [Re: Kern Dog] #1589857
03/12/14 06:10 PM
03/12/14 06:10 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
So I have to axe you guys - WHY do you run X-pipes?
Re: X pipe and mufflers. What do you run? [Re: Sunroofcuda] #1589858
03/12/14 06:28 PM
03/12/14 06:28 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
With an H-pipe my setup droned like crazy--drove me nuts.
On a suggestion I switched out the H-pipe with the universal Summit X-pipe and kept everything else the same--drone gone.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: X pipe and mufflers. What do you run? [Re: mopar_man] #1589859
03/12/14 08:58 PM
03/12/14 08:58 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
..... even I didn't believe like exhaust gases flowing forward rather than towards the tail pipes before entering a cat or muffler.
That was taught and proven in shop class, 1974.
Re: X pipe and mufflers. What do you run? [Re: BSB67] #1589860
03/12/14 09:07 PM
03/12/14 09:07 PM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
Must have been a well kept secret as not many people knew anything about what happens in front of a converter. BTw did they have converters in 74 ?
Re: X pipe and mufflers. What do you run? [Re: mopar_man] #1589861
03/12/14 09:52 PM
03/12/14 09:52 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I love that "sort of a X-pipe" as it has given me countless fun stories of how it came to be. I ran it on my roadrunner for awhile and it seemed to work fine and always was fun to have people who needed to look under the car ask about it.
What the heck maybe I will put it back on for Spring Fling??
Re: X pipe and mufflers. What do you run? [Re: mopar_man] #1589862
03/12/14 09:57 PM
03/12/14 09:57 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I happens in the entire exhaust system, not a function of the converter.
Re: X pipe and mufflers. What do you run? [Re: mopar_man] #1589863
03/13/14 12:01 AM
03/13/14 12:01 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I saw that picture that Stu put up. I didn't want to toss out any insults, but that does look strange!
I am intrigued about the references about exhaust gases flowing backward....
Is this supposed to mean that while the engine is forcing the exhaust out & thru the system, it is still possible that some pulses of the exhaust fights the pressure and moves back toward the front?
If this is true, what is this supposed to mean? What effect does it have ?
Re: X pipe and mufflers. What do you run? [Re: Kern Dog] #1589864
03/13/14 01:33 AM
03/13/14 01:33 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I run Dougs 452's with a 2 1/2" Pype's x pipe through Borla mufflers with tailpipes and tips. 383 has good sound at WOT and has absolutely no drone...or compression...or big bore...or big cam...but that's another story.
...FAFO...
Re: X pipe and mufflers. What do you run? [Re: skicker] #1589865
03/14/14 08:12 PM
03/14/14 08:12 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I'm getting ready to order the Magnaflow x pipe kit. I plan to cut and weld it in myself along with the new mufflers. I want to have flanges to be able to unbolt it in front of the mufflers. Flowmaster makes a ball flange pipe set that uses no gaskets but is $93 ! I may just weld the mufflers on for now and have a shop fab up some flanges later.
Re: X pipe and mufflers. What do you run? [Re: Kern Dog] #1589866
03/14/14 08:56 PM
03/14/14 08:56 PM
OT My next one I am going to incorporate 2 of those "mesh" connectors, 1 on each side that flex to help with ex system rattling & less stress on the header pri pipes/welds from the eng vibration/movement
Re: X pipe and mufflers. What do you run? [Re: RapidRobert] #1589867
03/17/14 02:03 PM
03/17/14 02:03 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
Here is a shot of my custom x pipe. I built it based on an article I found on the net that said that there is power to be found in a larger crossover area.
Re: X pipe and mufflers. What do you run? [Re: dynorad] #1589868
03/17/14 02:10 PM
03/17/14 02:10 PM
dynorad Offline
dynorad  Offline
Here is the article.
8077748-xfactorcolour.pdf (179 downloads)
Re: X pipe and mufflers. What do you run? [Re: dynorad] #1589869
03/17/14 02:12 PM
03/17/14 02:12 PM
Seattle, WA.
E
edp Offline
edp  Offline
E
Seattle, WA.
hows it work? I'm having duals installed right now with an X pipe but not like that I'm sure.
And since we're on exhaust, what is the difference between "HP / Magnum, Rams horn" manifolds for the 383 / 440 and stock ones?
Is it 2.5" vs. 2.25" ??
Re: X pipe and mufflers. What do you run? [Re: edp] #1589870
03/17/14 02:16 PM
03/17/14 02:16 PM
dynorad Offline
dynorad  Offline
It sounds nice with the 3" Ultraflows. I necked the pipe down to 2.5 for the tailpipes, and used TTI.
I haven't instrumented it to see what my backpressure numbers are but I'll bet they are negligible.
Re: X pipe and mufflers. What do you run? [Re: edp] #1589871
03/17/14 04:59 PM
03/17/14 04:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That and they should flow better .
Re: X pipe and mufflers. What do you run? [Re: dynorad] #1589872
03/18/14 01:09 AM
03/18/14 01:09 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Quite interesting. Thanks for the article too.
Re: X pipe systems: What do you run? GV or not? [Re: Kern Dog] #1589873
03/19/14 12:00 AM
03/19/14 12:00 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
The Magnaflow "Tru-X" kit arrived today. Man, stainless steel pipe looks nice!
Since I have a Gear Vendors overdrive in the car, the fitment of the X isn't going to be a slam dunk. It is because of this that TTI has a special exclusion for their kits in regards to these overdrive units.
I would think that it wouldn't be smart to place the X directly below the GV because the heat of the exhaust may cook the thin fluid inside. Does the exhaust run hot enough to pose a problem with that?
If I place the X in front of the GV, the exit from the headers has to make a sharper bend in a shorter space. I can easily place the X behind the GV. I'm just wondering if there are any drawbacks to placing the X back that far. Currently the Flowmaster muffler INlets are both inboard. To make the X fit, I'll have to place the Dynomax mufflers with the inlets toward each rocker panel. I see no problem with that but again, I was just curious what you think. It seems that as long as I have the inlets facing forward there shouldn't be any problems.
What is the likely effect of placing the X further back? Do you minimize some of the gains in torque?
Re: X pipe systems: What do you run? GV or not? [Re: Kern Dog] #1589874
03/23/14 09:25 PM
03/23/14 09:25 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
I finished up today. I ended up placing the X section directly under the front yoke of the driveshaft. I had a chop saw to cut the pipes which really helped. I still did the job with the car on jackstands which is obviously not fun nor easy. I tacked the 4 pipes and X together then unbolted it all to weld away from the car.
I had some nice welds and some sloppy ones. I had to take a grinder to smooth some over. I can believe how hard this metal is to grind down!
The car idles so quiet ! I can hear the cam and headers more than the exhaust coming from the tailpipes. At cruise it is so quiet I can hear a rear axle whine more than the engine. Funny how so many noises seem to blend together and you don't know that they are there.
power seems about the same. The air/fuel numbers are the same or a bit richer than before. I expected them to lean out. All in all, I'm quite happy that the car is quieter without a loss in power. It does have a growl compared to the raspy sound of the Flowmasters.
Re: X pipe and mufflers. What do you run? [Re: BSB67] #1589875
03/23/14 09:38 PM
03/23/14 09:38 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Is that what is refered to as reversion ??? Is'nt that why they "step" areas {smaller into a bigger port} like intake manifolds, head exhaust ports into bigger header primaries etc ?? Giving more resistance to the backflow pulses....
Glad to hear you've got the X pipe up and running... I used the TTI 3 inch H pipe for the GV unit and don't really mind the tone from it... I would'nt say it has a drone like some systems I've heard..
Page 2 of 3 1 2 3
