X pipe systems: What do you run? GV or not?
#1589836
03/08/14 02:57 AM
03/08/14 02:57 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I want to make a change to my exhaust system in the Charger. 493 with a 727 and a gear Vendors overdrive. Currently I have 2" TTI headers on the 493. I have 2 1/2" pipes with Flowmaster 42541 mufflers and 2 1/2" tailpipes. A month ago I added a 2 1/4" H pipe. I looked at the TTI site and saw that they do have a 3" exhaust system for my car but their X pipe kit doesn't fit cars with the Gear Vendors OD. I figure I'll piece together some stuff and let a muffler guy bend the pipes and weld it all up. I've read good things about the Dynomax Welded Ultra Flo mufflers. Summit has this welded X pipe: http://www.summitracing.com/parts/jex-xp6/overview/I have seen other types elsewhere though. Some look like 2 pipes laid alongside each other. Which do you think are more effective? I understand that the advantages of the X pipe is additional torque and slightly quieter exhaust tone.
Re: Many types of exhaust X pipes !
[Re: RylisPro]
#1589839
03/08/14 12:03 PM
03/08/14 12:03 PM
Posts: 3,152 Central NC
gch
Central NC
The magnaflow tru x is a nice piece.I have the original(?) x pipe on my Polara (Dr Gas) and will buy another from them if ever needed. http://www.drgas.com/xpipes
Re: X pipe and mufflers. What do you run?
[Re: Kern Dog]
#1589841
03/09/14 01:20 PM
03/09/14 01:20 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
So, for comparison sakes, I'll talk about my 04 Ram, 5.7. I had the stock exhaust and 55 Gallon drum sized muffler replaced. Based on the muffler shops recommendation, I first installed 2 1/2" necking down to 2 1/4" at the tips, duals with an x-pipe and MagnaFlow 18" mufflers. Since this is a tow vehicle, I was mainly looking for more efficiency and a little power. It was much louder and droned at interstate speeds and I had a lost of MPG. The vehicle is stock with a chip and CAI.
I then had the magna flows removed, installed Dynomax VT's. The drone is gone. Still no seat of the pants power difference feel. Mileage is back up to where is was stock. It does sound better. All in all I wish I'd just left the stock exhaust on it. However, had I changed exhaust manifolds to headers, maybe I would of had better results.
[Re: MidPenMopar]
#1589847
03/10/14 02:26 AM
03/10/14 02:26 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
2" TTI headers and the 3" TTI X-pipe system out to rear bumper with Dyno-Max Ultra-Flow mufflers. It sounds great to me and no drone at all. I have never uncapped it as I always race it throught the full exh. Here is a clip where you can here it some. Ron http://www.youtube.com/watch?v=bYIM2HLaOI4
[Re: RylisPro]
#1589849
03/11/14 11:03 PM
03/11/14 11:03 PM
Kern Dog
Granite Bay CA
I checked the links everyone here listed. lots of viable options. I was on the Summit site and saw this: http://www.summitracing.com/parts/mpe-16405/overview/The pictures look like a generic that they probably use for all pipe sizes. I like that the pipes are Mandrel bent. The price seems fair. I've never tried to weld stainless steel though. Is it any different than regular steel? I have the .030 wire MIG with the CO2/Argon tank.
[Re: Kern Dog]
#1589851
03/12/14 10:46 AM
03/12/14 10:46 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
That's an interesting design as the side cross in the X , it's a true X , the typical X are 2 45* U type bends that are connected by a hole between the 2 bends.
[Re: mopar_man]
#1589853
03/12/14 01:18 PM
03/12/14 01:18 PM
Posts: 4,664 Newfoundland
mopar_man
Newfoundland
Don't believe all that is written about the "H" and "X" pipe configs. My brother has spent at least 20 yrs working with the EPA, California Air Resources Board(CARB), Environment Canada, and many certified testing lab like Carnot Industries in Texas and test labs here in Canada. He has shown them and proven to them things about catalytic converters and exhaust systems that even I didn't believe like exhaust gases flowing forward rather than towards the tail pipes before entering a cat or muffler. As for what to run , it will depend on what the OP wants . sound is one thing , heat buildup , power increase /decrease, and what pollutants are being exhausted are all into the mix . The problem is , its not cheap to try several different X or H pipes and end up only using one. Before the OP buys anything ,he should check out other cars that have similar specs as his car and see what he likes and go for it .
[Re: Kern Dog]
#1589855
03/12/14 03:49 PM
03/12/14 03:49 PM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
Ditch I run the Summit 3 inch on my 65 440.Then it goes to their stainless muffler exit at front of rear wheels.Its pretty quiet but has a great sound when you get into it.I cant understand why people pay over 100 bucks a muffler for a name.the Summit SS are super quality and a work of art.If they had a name on them they would probally be 200 each.Rocky
Chrysler Firepower
