Ed Hamburger Vintage Parts from the 1970's & 1980's #1588738
03/06/14 01:51 PM
03/06/14 01:51 PM
Connecticut
1972CudaV21 Offline OP
Connecticut
Are any of you guys still running any vintage Ed Hamburger parts that he sold during the 1970's and 1980's for the 340/360??
Any pics of his old oil pans for the small block Mopar? What made them special?
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: 1972CudaV21] #1588739
03/06/14 02:51 PM
03/06/14 02:51 PM
Locomotion Offline
Locomotion  Offline
I believe he was the first Mopar source to sell trick/custom parts in volume to Mopar racers. I use to buy quite a bit from him back then. I don't have any pics, but do have a couple of his old catalogs. That's where I first learned about crank scrapers, modified windage trays and more.
Moparts member "Topside" has an ex-Hamburger team car (Super Stock Duster, I believe) and likely a lot more info on the cars & parts.
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: 1972CudaV21] #1588740
03/06/14 02:54 PM
03/06/14 02:54 PM
AndyF Offline
AndyF  Offline
One reason I started building my own parts was because the parts I bought from Hamburger were such poor quality. I looked at those parts and the price I paid for them and decided I could do better. That was a long time ago but it is one of the things that started me down the path of designing and building my own stuff.
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: 1972CudaV21] #1588741
03/06/14 06:32 PM
03/06/14 06:32 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I still have a set of Hamburger's "stocker" leaf springs,and a few other items.
Nautilus Racing-
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: Chris2581] #1588742
03/06/14 07:35 PM
03/06/14 07:35 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Got a hamburger deep sump pan...needs a little repair ..have had it since 80s...
got a few small parts with his part numbers still on them...harden washers...5/64 4.07 ring set..probably reboxed sealed power rings..
and .984 tool steel 80 gram wrist pins..after buying them in the 80s finally put them in a engine last year...
Tony
70 AARCuda Vitamin C
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: AndyF] #1588743
03/06/14 07:45 PM
03/06/14 07:45 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Sounds like the same reason I switched to assembling my own engines after paying "professionals" to do the work and still experiencing issues that IMO could have been avoided.
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: BradH] #1588744
03/06/14 07:49 PM
03/06/14 07:49 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I have one of the adjustable timing gears for an A engine. I was always scared to put it on though.
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: DavidDean] #1588745
03/07/14 03:03 PM
03/07/14 03:03 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
A bunch of us got the distributor stablizer (the collar with set screw to prevent the oil pump drive bouncing up and down changing timing conditions. Still have it, and lost count the number of motors it's been in.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: Slingshot383] #1588746
03/07/14 03:24 PM
03/07/14 03:24 PM
Connecticut
Connecticut
Do you think it helped?
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: AndyF] #1588747
03/07/14 03:32 PM
03/07/14 03:32 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We still have some of their overpriced stuff in the attic.Some of their oil pan designs are good for lawn sprinklers and some of their internal parts are great for comming apart and causing engine failres.
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: 1972CudaV21] #1588748
03/07/14 03:46 PM
03/07/14 03:46 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
I bought the street/strip oil pan for a 340. The pan fit well and did not hang down very far past the K-member. I think it was a 6 qt and had accel/decel baffles. I have a pic somewhere. If you want, I can post later tonight. Also, bought tool steel lightweight wrist pins. Tried to order parts after they moved to Wirtz, VA, but did not have much luck. I think whoever he sold the business to kept the name, but the service and tech dept was lousy. Still have an old performance catalog from the '80s.
John
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: DusterW2] #1588749
03/07/14 08:42 PM
03/07/14 08:42 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Ironically not much of his stuff is still on my/his car; what's there is mostly "extra-legal" fab tricks. The car with the most cleverness (and success) is the old Hamburger, Bachelder & Chipman car. Herb McCandless did a lot of work on some of the cars - HBC & Ed's/mine for sure.
Judging by my archive of the team cars and team members, Ed's strength was in thinking up ways to step up the SB. I can't say much about the 340/360 Only parts, as so few are around. Much if not all of that stuff was 1st run on my car or the other team cars. After he sold the Hamburger company, the guys that bought it were apparently pretty bad at quality & service from what I've heard.
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: topside] #1588750
03/07/14 10:49 PM
03/07/14 10:49 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I bought his stuff years ago, thought that sb windage tray with the extra louvers was a good idea
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: DusterW2] #1588751
03/08/14 11:50 PM
03/08/14 11:50 PM
Connecticut
Connecticut
John
If you can post up a pic of the street/strip oil pan, that would be great!
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: 1972CudaV21] #1588752
03/09/14 11:06 AM
03/09/14 11:06 AM
hiding in illinois
slax69gts Offline
slax69gts  Offline
hiding in illinois
a year ago at a swap meet in milwaukee i bought a welded sheet aluminium oil pan for my 470. the seller said it was a ed hamburger unit but there were no markings or tags. i did a web search but the closest pan i found was one that 440 source had that was kind of like it. seems he did alot of cheby stuff. i cleaned it up and had the external pick up hole welded up then knocked in two holes for a swinging pick up. i may use it, maybe not...
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: slax69gts] #1588753
03/09/14 11:24 AM
03/09/14 11:24 AM
N.Y.
sixpacksteve Online content
sixpacksteve  Online Content
N.Y.
here's a rb pan
Hell Hath No Fury Like Mine
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: sixpacksteve] #1588754
03/09/14 11:41 AM
03/09/14 11:41 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Not knocking anyones product but simply recalling old issues that we seen with some of their parts ie:
Distributer shaft stabalizers that fell apart and cause major internal engine damage.
Oil pans that leaked like lawn sprinklers at seams and welds.
Crank scrapers and windage trays that cracked and caused internal damage as well as crank and rod interference..
Pan rails and bolt holes alignment and placement.
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: 1972CudaV21] #1588755
03/09/14 03:36 PM
03/09/14 03:36 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
340 Ed Hamburger oil pan from 1989 -
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: B G Racing] #1588756
03/10/14 07:31 PM
03/10/14 07:31 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Had one of his aluminum 340 pans, with the tube for the center link. Had a pickup and plate that bolted directly onto the oil pump, after removing the rotor cover. First fire up on a new motor, the rotors bound up against the pickup plate,locking the oil pump and shearing the pin in the distributor drive. Needless to say that pan and pickup came right out.
Re: Ed Hamburger Vintage Parts from the 1970's & 1980's [Re: B G Racing] #1588757
03/11/14 01:25 AM
03/11/14 01:25 AM
Connecticut
Connecticut
Thanks for the reality check...lol. Did they make any good parts??
