833 transmission #1575921
02/08/14 06:04 PM
02/08/14 06:04 PM
WV, USA
donsdart Offline OP
donsdart  Offline OP
WV, USA
Any ideas why a newly rebuilt 833 will slip from 4th gear when decelerating or coasting downhill? Does not do this in any other gear or during acceleration.
Re: 833 transmission [Re: donsdart] #1575922
02/08/14 06:09 PM
02/08/14 06:09 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Either it wasn't fully rebuilt (the hubs, dogs, and sliders wear) or the shifter should be adjusted one turn longer on every rod (this "trick" worked on my son's 18-spline that was NOT fully rebuilt).
Re: 833 transmission [Re: Jim_Lusk] #1575923
02/08/14 06:25 PM
02/08/14 06:25 PM
WV, USA
donsdart Offline OP
donsdart  Offline OP
WV, USA
Thanks Jim, I adjusted 4th gear out one turn with no improvement. I'll try the rest and see what happens. May have to crack it open!
Re: 833 transmission [Re: donsdart] #1575924
02/08/14 06:51 PM
02/08/14 06:51 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Turn it one turn the other way (so, two turns back the other way). If this doesn't work, it's time for a real full rebuild (which I have never done, and I've been through a few of these).
Re: 833 transmission [Re: Jim_Lusk] #1575925
02/08/14 07:00 PM
02/08/14 07:00 PM
WV, USA
donsdart Offline OP
donsdart  Offline OP
WV, USA
Will do. Are you saying to back all rods off 2 turns or just 4th gear?
Re: 833 transmission [Re: donsdart] #1575926
02/08/14 07:10 PM
02/08/14 07:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Bellhousing misalignment will make it pop out of 4th on deceleration.
Re: 833 transmission [Re: donsdart] #1575927
02/08/14 07:12 PM
02/08/14 07:12 PM
I'm out on a limb here cuz I ain't a stick guy but I'd put the 1-2 & 3-4 trans levers in neutral the stick the drill bit thru the shifter to line it up then adj the rod threaded lengths till the L bends fit right into the hole(s) in the trans levers. If that didn't solve it then I'd: with the 3-4 trans lever disconnected I would shift the trans lever to put the trans in 4th then shift the shifter handle to 4th & see if the rod length makes it line up with the hole in the 3-4 trans lever on the side of the trans & adj it if needed & retry.
Re: 833 transmission [Re: RapidRobert] #1575928
02/08/14 07:37 PM
02/08/14 07:37 PM
SW CO
HemiSportFury Offline
SW CO
You may need to adjust to stop screw to make sure it goes all the way into 4th. Adjust the shift rods as described above, shift into 4th, disconnect the 4th gear rod at the lever end, and see if it needs to travel any more to get fully into gear. The FSM calls out the required free play or gap to be set at the stop.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: 833 transmission [Re: donsdart] #1575929
02/08/14 07:54 PM
02/08/14 07:54 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The rods all need to be adjusted the same so that neutral is even. This isn't a fix, really, but it will get you by sometimes. John has more experience than I do and he might also be correct.
Re: 833 transmission [Re: RapidRobert] #1575930
02/08/14 08:57 PM
02/08/14 08:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That is how I do it, but it was on a freshly rebuilt A833, I rebuilt it so I know all was done right, and a brand new shifter. Adjusted the rods till the slipped in without any drag and I used meatl bushings and new clips that I shimmed the slack out of. http://www.jegs.com/i/Hurst/530/332-7302/10002/-1?parentProductId=749352
Worked properly.
But if things are worn you may have to fiddle with it.
Don't be the exception.
Re: 833 transmission [Re: Supercuda] #1575931
02/08/14 09:46 PM
02/08/14 09:46 PM
WV, USA
donsdart Offline OP
donsdart  Offline OP
WV, USA
Thanks to everyone for your help. I found no bushings in the linkage, so I will order a set of metal bushings and realign everything. This is a hemi in a 65 Belvedere and things tend to be weird!
Re: 833 transmission [Re: donsdart] #1575932
02/08/14 09:47 PM
02/08/14 09:47 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
If after doing all of the adjusting that has been recommended and you see no improvement, .... When the transmission was rebuilt do the input shaft get replaced? (4th gear)? When a trans pops out on deceleration in any gear, it usually means the "dog" teeth are worn. I would,however,start with making sure the shifter is adjusted properly, and that the transmission is going all the way into gear. (ALWAYS do the easy stuff FIRST)
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 833 transmission [Re: John_Kunkel] #1575933
02/08/14 10:33 PM
02/08/14 10:33 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
this is the first thing that needs to be checked. Pilot bushing in good shape? Who did the rebuild? does the brg ret size match bell? If shifter linkage is adjusted and everything else checks ok trans needs to come apart.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
