Page 2 of 6 1 2 3 4 5 6
Re: Duster front end updates are done [Re: 1967dartgt] #1575096
02/07/14 01:17 PM
02/07/14 01:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
and this my friend is NOT stock front suspension.
Why? Does the a arm bolt on in the stock location? Does the sub frame still bolt on in the stock location? Does it not still use a stock spring location? So stock arm mounting points, stock spring location, and bolts on like stock sub frame with stock frame rails but it's not stock how do you figure?
I would call it a modified front end.. not stock
Re: Duster front end updates are done [Re: MR_P_BODY] #1575097
02/07/14 02:03 PM
02/07/14 02:03 PM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
You guys are wasting tour time arguing with this guy and many others. They manipulate those rules as they chose. The STOCK firewall rule is a real sketchy subject.
I'll stick to my bracket racing.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Duster front end updates are done [Re: pittsburghracer] #1575098
02/07/14 02:05 PM
02/07/14 02:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lookin good...............Looks so much nicer that the stock stamped junk I run now............
Re: Duster front end updates are done [Re: pittsburghracer] #1575099
02/07/14 02:09 PM
02/07/14 02:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I agree... I'm not arguing but call it like I see it
again thats the way "I" see it.... your right.. I
like the rules in bracket racing.. they fit my rules
Re: Duster front end updates are done [Re: 1967dartgt] #1575100
02/07/14 02:11 PM
02/07/14 02:11 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
Factory cut out and aftermarket "WELDED" in.
It's not a direct bolt in, if it was then I would agree.
BUT, the key word here is WELD...
It's a bigblock with a torque flight!!!
Re: Duster front end updates are done [Re: 1967dartgt] #1575101
02/07/14 02:22 PM
02/07/14 02:22 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you have to be kidding stock means the way it came from the factory unchanged in any way. there is no difference in that front end with round tubes or not. just a twist of rules to fit your needs, class or what ever you want to call it. IT IS A FAB TUBE CHASSIS.
Re: Duster front end updates are done [Re: Quicktree] #1575102
02/07/14 02:31 PM
02/07/14 02:31 PM
PA.
"Little"John
"Little"John
PA.
Not that there's anything wrong with that.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Duster front end updates are done [Re: pittsburghracer] #1575103
02/07/14 02:43 PM
02/07/14 02:43 PM
Pittsburgh
ChuckT Offline
ChuckT  Offline
Pittsburgh
Looks good, John! Orie does nice work!
Re: Duster front end updates are done [Re: mopar_to_ya] #1575104
02/07/14 03:49 PM
02/07/14 03:49 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
This is a Camaro front sub frame, it unbolts from the factory. The left and right rail are are factory stamped pieces from where they bolt on the car too where the a arms bolt on. They bolt on the same way and location as a factory car. He cut out cross member welded new one in. He cut and welded in tube core support. He didn't change anything as far as location or how it attaches in refused to the front suspension. So it is infact completely bolt on. Is your brother's car stock suspension?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Duster front end updates are done [Re: pittsburghracer] #1575105
02/07/14 08:49 PM
02/07/14 08:49 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Ok this is how I see it. If I can unbolt his sub frame and bolt it on another stock 70 Camaro with out any mods, or unbolt his a arms and springs and shocks and bolt them on another 70 Camaro with out mods how can this car not have stock suspension? He modified his cross member and rad support not his suspension. So if I but a rancho shock on my car it is not longer stock suspension you are telling me.
Re: Duster front end updates are done [Re: 1967dartgt] #1575106
02/07/14 08:54 PM
02/07/14 08:54 PM
PA.
"Little"John
"Little"John
PA.
Do you argue with yourself in the shower?
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Duster front end updates are done [Re: pittsburghracer] #1575107
02/07/14 10:41 PM
02/07/14 10:41 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Re: Duster front end updates are done [Re: 1967dartgt] #1575108
02/07/14 10:43 PM
02/07/14 10:43 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Re: Duster front end updates are done [Re: 1967dartgt] #1575109
02/08/14 01:35 AM
02/08/14 01:35 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If it passes tech then that's all that matters. That being said. If I wrote rules for stock suspension, I would tighten them to eliminate this being a "stock" front suspension. I can't believe this was the intent of the rules. The only factory parts are the rails. Kind of reminds me of when there was no wording about nitrous in NHRA Pro Stock. I applaud the owners use of stretching the rules. That's thinking outside the box. So until it's deemed illegal, I'd run it. But in my book it's nowhere near stock
Doug
Re: Duster front end updates are done [Re: n20mstr] #1575110
02/08/14 01:35 AM
02/08/14 01:35 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
wow that don't have NOTHING stock about it.....,! Lol
But its NA!
Update looks good! New hardware is always nice
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Duster front end updates are done [Re: dvw] #1575111
02/08/14 02:11 AM
02/08/14 02:11 AM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
The Camaro subframe will pass for stock style suspension in any backhalf class. The Duster at the top would be a tube chassis car.
Re: Duster front end updates are done [Re: 1967dartgt] #1575112
02/08/14 05:42 AM
02/08/14 05:42 AM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
Are you freakin kidding me!
This is a joke.
IF IT'S CUT, MODIFIED, AND/OR WELDED, then it's NOT
a direct bolt in... Therefor it is NOT STOCK!
Who gives two craps if the subframe bolts in or not, big whoopee do.
Re: Duster front end updates are done [Re: 1967dartgt] #1575113
02/08/14 01:41 PM
02/08/14 01:41 PM
PA.
"Little"John
"Little"John
PA.
Look at this his tube chassis unbolts
What does a CHEVY front frame section have to do with this post anyway? Just curious.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Duster front end updates are done [Re: 1967dartgt] #1575114
02/08/14 01:56 PM
02/08/14 01:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
How about these guys?
http://www.yellowbullet.com/forum/showthread.php?t=700969
Too funny, go to other sites and call us "Moparts" guys knuckleheads........AND promote gm crap............
Re: Duster front end updates are done [Re: Thumperdart] #1575115
02/08/14 02:04 PM
02/08/14 02:04 PM
PA.
"Little"John
"Little"John
PA.
I guess a STOCK modified chevy front end would look stock to a chevy guy. Sometimes you wish some of our mopar guys played for the other team.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
