Re: Duster front end updates are done
[Re: 1967dartgt]
#1575096
02/07/14 01:17 PM
02/07/14 01:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
and this my friend is NOT stock front suspension.
Why? Does the a arm bolt on in the stock location? Does the sub frame still bolt on in the stock location? Does it not still use a stock spring location? So stock arm mounting points, stock spring location, and bolts on like stock sub frame with stock frame rails but it's not stock how do you figure?
I would call it a modified front end.. not stock
[Re: 1967dartgt]
#1575101
02/07/14 02:22 PM
02/07/14 02:22 PM
Quicktree
you have to be kidding stock means the way it came from the factory unchanged in any way. there is no difference in that front end with round tubes or not. just a twist of rules to fit your needs, class or what ever you want to call it. IT IS A FAB TUBE CHASSIS.
[Re: pittsburghracer]
#1575105
02/07/14 08:49 PM
02/07/14 08:49 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Ok this is how I see it. If I can unbolt his sub frame and bolt it on another stock 70 Camaro with out any mods, or unbolt his a arms and springs and shocks and bolt them on another 70 Camaro with out mods how can this car not have stock suspension? He modified his cross member and rad support not his suspension. So if I but a rancho shock on my car it is not longer stock suspension you are telling me.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1575106
02/07/14 08:54 PM
02/07/14 08:54 PM
Posts: 20,194 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Do you argue with yourself in the shower?
[Re: 1967dartgt]
#1575112
02/08/14 05:42 AM
02/08/14 05:42 AM
Posts: 1,327 south central,Pa
mopar_to_ya
south central,Pa
Are you freakin kidding me! This is a joke. IF IT'S CUT, MODIFIED, AND/OR WELDED, then it's NOT a direct bolt in... Therefor it is NOT STOCK! Who gives two craps if the subframe bolts in or not, big whoopee do.
It's a bigblock with a torque flight!!!
