Re: Challenger 6 Pak Shaker Setup
[Re: magnum440]
#1555264
01/14/14 12:45 AM
01/14/14 12:45 AM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
What was the original material of the shaker bubble?
It was a material commonly used in the RIM and compression molding process. A multi component mixture of resins, plasticizers, and filler solids used to add structure (glass fibers, talc, etc. most of which are engineered to be highly resistant to fire and heat). The resins were a catalyzed mix that were blended and molded under heat and pressure. The process required very expensive tooling and machines to run them in, not practical to reproduce in our world, the minimum numbers are far too small to make the venture economical. This is why todays reproductions are all fiberglass, no real tooling costs, low cost materials, made one at a time with no large runs required.
[Re: ScottSmith_Harms]
#1555265
01/14/14 03:14 PM
01/14/14 03:14 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I am looking to convert my car to a Shaker that is mostly strip but will be driven on the street also. I am not looking for 100% accuracy just want the look as I will be running a high rise single manifold with a Dominator so I will be modifying & making a drop base anyway. Who's would be the best looking for the least expensive $ amount???
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1555266
01/14/14 03:19 PM
01/14/14 03:19 PM
Posts: 18,157 Mass
DAYCLONA
Mass
In that case, light weight is your friend for a strip car, fiberglass shaker hood, lift off or bolt on, with a fiberglass scoop attached to the underside of the hood, still functional as far as fresh air, but without the hassle of baseplates, cables, aircleaners,seals, doors, etc, this way you could run any aircleaner/carb set under the scoop you desired, several vendors offer this set up
Mike
[Re: DAYCLONA]
#1555267
01/14/14 04:03 PM
01/14/14 04:03 PM
6PKRTSE
Motor City
Mike
I have been looking at those also. Also thought about just running the carb & air cleaner thru the shaker hole in the hood. Anyone else try this? Will it still work with the offset engine placement & the hole being centered???
[Re: 2fast4yourBrain]
#1555269
01/15/14 03:42 AM
01/15/14 03:42 AM
Posts: 1,187 USA
big-block-dave
USA
OK, so i'm following.....my friend is doing a RARE '70 'cuda for a customer. The owner wants to "add" the shaker hood set up. He has the AMD hood and trim ring. Told me he's looking for all the rest for 4bbl setup. HELP>>>>>>>>please
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: big-block-dave]
#1555270
01/15/14 03:29 PM
01/15/14 03:29 PM
Posts: 6,085 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
PM me. I got hot/cold shaker doors for sale.
[Re: DAYCLONA]
#1555274
02/24/14 05:24 PM
02/24/14 05:24 PM
Posts: 554 WI.
Scotts71chall
WI.
Mike
This is the exact bolt on setup im looking for! Please give me a name that has the bubble attached to the hood. I seen one many years ago on e-bay but non since.
