Re: Challenger 6 Pak Shaker Setup [Re: magnum440] #1555264
01/14/14 12:45 AM
01/14/14 12:45 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
What was the original material of the shaker bubble?
It was a material commonly used in the RIM and compression molding process. A multi component mixture of resins, plasticizers, and filler solids used to add structure (glass fibers, talc, etc. most of which are engineered to be highly resistant to fire and heat). The resins were a catalyzed mix that were blended and molded under heat and pressure. The process required very expensive tooling and machines to run them in, not practical to reproduce in our world, the minimum numbers are far too small to make the venture economical. This is why todays reproductions are all fiberglass, no real tooling costs, low cost materials, made one at a time with no large runs required.
Re: Challenger 6 Pak Shaker Setup [Re: ScottSmith_Harms] #1555265
01/14/14 03:14 PM
01/14/14 03:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I am looking to convert my car to a Shaker that is mostly strip but will be driven on the street also. I am not looking for 100% accuracy just want the look as I will be running a high rise single manifold with a Dominator so I will be modifying & making a drop base anyway. Who's would be the best looking for the least expensive $ amount???
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Challenger 6 Pak Shaker Setup [Re: 6PKRTSE] #1555266
01/14/14 03:19 PM
01/14/14 03:19 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
In that case, light weight is your friend for a strip car, fiberglass shaker hood, lift off or bolt on, with a fiberglass scoop attached to the underside of the hood, still functional as far as fresh air, but without the hassle of baseplates, cables, aircleaners,seals, doors, etc, this way you could run any aircleaner/carb set under the scoop you desired, several vendors offer this set up
Mike
Re: Challenger 6 Pak Shaker Setup [Re: DAYCLONA] #1555267
01/14/14 04:03 PM
01/14/14 04:03 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mike
I have been looking at those also. Also thought about just running the carb & air cleaner thru the shaker hole in the hood. Anyone else try this? Will it still work with the offset engine placement & the hole being centered???
Re: Challenger 6 Pak Shaker Setup [Re: 6PKRTSE] #1555268
01/15/14 02:38 AM
01/15/14 02:38 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Curious, who supplies the YO bubbles?
If it's a Gene bubble, it should have the initials "ACS" on the underside.
Re: Challenger 6 Pak Shaker Setup [Re: 2fast4yourBrain] #1555269
01/15/14 03:42 AM
01/15/14 03:42 AM
USA
big-block-dave Offline
USA
OK, so i'm following.....my friend is doing a RARE '70 'cuda for a customer. The owner wants to "add" the shaker hood set up. He has the AMD hood and trim ring. Told me he's looking for all the rest for 4bbl setup.
HELP>>>>>>>>please
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
Re: Challenger 6 Pak Shaker Setup [Re: big-block-dave] #1555270
01/15/14 03:29 PM
01/15/14 03:29 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
HELP>>>>>>>>please
PM me. I got hot/cold shaker doors for sale.
Re: Challenger 6 Pak Shaker Setup [Re: big-block-dave] #1555271
01/15/14 04:03 PM
01/15/14 04:03 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
If its so "rare" why is he adding options? Bad move in most cases.
Re: Challenger 6 Pak Shaker Setup [Re: ScottSmith_Harms] #1555272
01/16/14 12:20 AM
01/16/14 12:20 AM
GA
roadrunninMark Offline
GA
Re: Challenger 6 Pak Shaker Setup [Re: roadrunninMark] #1555273
02/24/14 02:12 PM
02/24/14 02:12 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Has anyone bought the hot/cold air doors for the shaker from Mega Parts? How good is the quality and replication?
Re: Challenger 6 Pak Shaker Setup [Re: DAYCLONA] #1555274
02/24/14 05:24 PM
02/24/14 05:24 PM
WI.
Scotts71chall Offline
WI.
Mike
This is the exact bolt on setup im looking for! Please give me a name that has the bubble attached to the hood. I seen one many years ago on e-bay but non since.
Re: Challenger 6 Pak Shaker Setup [Re: Scotts71chall] #1555275
02/24/14 07:16 PM
02/24/14 07:16 PM
illinois
scottyb1955 Offline
scottyb1955  Offline
illinois
I bought a shaker hood a trim ring from AMD a couple months ago and the ring that it comes with dose not fit the back of hood at all I can get the tip of my finger in the gap. They said the ring comes from shakerhood.com I know they did not fit perfect from the factory but just be aware that you will need to put some time into making it fit if you get it from them, they forget to tell you about that part. The shaker stuff Year One sells from what I have found is no better than anyone else it just cost a lot more.
Re: Challenger 6 Pak Shaker Setup [Re: scottyb1955] #1555276
02/24/14 07:40 PM
02/24/14 07:40 PM
pawling n.y.
cudachas Offline
cudachas  Offline
pawling n.y.
Just did this with my 70 cuda. Bought the complete kit from six pack performance (minus hood).Art will paint the bubble what ever color and install the grills (which I am told is a real PIA).Fit and finish was excellent.I used a BE&A trim ring and a hood from Shermans (which I believe was from Goodmark)and I am satisfied with the end results. My paint guy said the hood needed minor work and fit very well for an aftermarket product.I would call Art at Six Pack Performance and talk to him about putting together a package deal. Just my opinion.Good luck!
Re: Challenger 6 Pak Shaker Setup [Re: cudachas] #1555277
02/24/14 08:01 PM
02/24/14 08:01 PM
South Georgia
tx9cuda Offline
tx9cuda  Offline
South Georgia
I just installed a shaker on my Cuda and used a bubble that I got directly from GG. There is a lot of fit and finish required for the grills and hot/cold doors including drilling and tapping for all of the fasteners. Just a warning these bubbles are no where close to finished. Letting Art do it for you may be a strong factor in your choice. Also Roseville parts sells some really nice finished grills.
Bryan
1971 BS23H1B
