What cam in your SB stroker ? #1517592
10/14/13 08:14 PM
10/14/13 08:14 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Just a quick survey......
What cam (duration) are your running in you 408/416 ? and what ET ??
I run:
255/263 at .050 1.39 60', 6.55 1/8 mile
Re: What cam in your SB stroker ? [Re: Wedgeman] #1517593
10/14/13 08:35 PM
10/14/13 08:35 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my old 416 was a solid roller 268/272@ .050 .690 lift 9.76 at 138 in a 3000lb car.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: What cam in your SB stroker ? [Re: dusturbd340W5] #1517594
10/14/13 08:48 PM
10/14/13 08:48 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
just a little question.. but would/could you drive this grind with this cubic inch combo on the street? Behaviour?
Re: What cam in your SB stroker ? [Re: Wedgeman] #1517595
10/14/13 09:09 PM
10/14/13 09:09 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Mine is 255/266 @.050. Solid roller,but mine is only a 394 ci.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: What cam in your SB stroker ? [Re: Hot 340] #1517596
10/14/13 11:28 PM
10/14/13 11:28 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
I'm a little more cubes at 439 but I run a .725 lift 272/276 and it is street driven lots (as much as possible with our short season) and it's street manners are just fine. Actually could have been more radical and been ok yet.
Re: What cam in your SB stroker ? [Re: Wedgeman] #1517597
10/15/13 10:56 AM
10/15/13 10:56 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Racer Brown STX22--Solid Lifter flat tappet--276@.050--.590" lift--1.260 60ft--6.09 at 111mph 1/8th mile--9.68 at 136mph 1/4 mile--3075# 72 Demon--Hand ported smog era 360 heads, [587 castings]--1800+ runs and counting
Re: What cam in your SB stroker ? [Re: qwkmopardan] #1517598
10/15/13 12:18 PM
10/15/13 12:18 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
wow !!!
And what's your cr ? weight ?
Re: What cam in your SB stroker ? [Re: Wedgeman] #1517599
10/15/13 12:25 PM
10/15/13 12:25 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Small solid roller, 248/254 duration, .576/.582 lift, pump gas street car, 3200 lbs, 6.81 @ 99.7 in the 1/8 (high 10.70's in the 1/4).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: What cam in your SB stroker ? [Re: FlyFish] #1517600
10/15/13 05:34 PM
10/15/13 05:34 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
440sb. solid roller, 272/276, 730-704 lift. 2937#, 9.61@138, 60'-1.25
Re: What cam in your SB stroker ? [Re: Hot 340] #1517601
10/15/13 09:28 PM
10/15/13 09:28 PM
Kissimmee Fl.
Kissimmee Fl.
with out a doubt before I had to sell it I was looking at putting it on the street.
motor was very well mannered never loaded up idled very nice at 950-1000 in N would idle all day and never get over 190 deg.
Re: What cam in your SB stroker ? [Re: dusturbd340W5] #1517602
10/16/13 10:24 PM
10/16/13 10:24 PM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
solid roller 254/262 0n 107 lc 660 lift .3550 lbs 1.37 60 ft 6.0 113 and 9.57@142
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: What cam in your SB stroker ? [Re: Ian] #1517603
10/17/13 07:41 PM
10/17/13 07:41 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
solid roller 254/262 0n 107 lc 660 lift .3550 lbs 1.37 60 ft 6.0 113 and [Email]9.57@142[/Email]
You are running NOS also, correct?
Re: What cam in your SB stroker ? [Re: D-50] #1517604
10/17/13 07:56 PM
10/17/13 07:56 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
254/254@.050, .748lift w/1.70 rockers, its a hughes HER5454AS its on lob sep. 106*/instaled 103*, my engine is only a 366cu. but puts 728hp to the ground,this is a circle track dirt car, jusy bad ass fast,puts the hamer to a lott 421 junk-a-lays
Re: What cam in your SB stroker ? [Re: jg309] #1517605
10/17/13 08:36 PM
10/17/13 08:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
408", 260/264 @ .050, .628/.633 flat solid, 6.57, 1.38 60' at 3260# on pump 93 and 4.10 gears.
Re: What cam in your SB stroker ? [Re: justinp61] #1517606
10/17/13 10:59 PM
10/17/13 10:59 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
408 667in, 675ex, 264/270 comp roller, 1.6 T&D
Re: What cam in your SB stroker ? [Re: D-50] #1517607
10/18/13 02:32 AM
10/18/13 02:32 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
correct
Re: What cam in your SB stroker ? [Re: Ian] #1517608
10/18/13 01:14 PM
10/18/13 01:14 PM
Guitar Jones Offline
Old Crane SS solid roller. 276/282 @ .050 and net lift with lash and 1.6 rockers is .698/.714. 408, W5's and 2-750's on a M1 TR. Probably not an ideal cam but it was only $75.00 with only 10 dyno pulls on it.
Re: What cam in your SB stroker ? [Re: Guitar Jones] #1517609
10/18/13 02:35 PM
10/18/13 02:35 PM
Minot, ND
darndart Offline
darndart  Offline
Minot, ND
Just putting the finishing assembly on a 410 for my 73 Dart Sport. It's got a Comp Solid Roller 269/276 @ .050 with .698/.698 w/ 1.6's. Hope to run in the 9.70 range!
73 Dart Sport 340, 410ci, Indy 360-2 230CNC.
72 Demon 340 4-speed
01 Ram Quad Cab
89 Mustang LX Boss 331,C4,HP76mm turbo, FAST EFI
86 Mustang GT 5.0 AOD
82 Capri RS 306, Fox Lake Stage 1 TW, N41, T5,etc.
Re: What cam in your SB stroker ? [Re: darndart] #1517610
10/18/13 02:39 PM
10/18/13 02:39 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
got a 408 with ported eddy heads, with KB icon 744 pistons and scat I beam rods, Cam is a hughes 264/268 flat tappet with crane gold rockers...
Engine is still on engine stand...
Tony
70 AARCuda Vitamin C
