Re: What cam in your SB stroker ?
[Re: Wedgeman]
#1517593
10/14/13 08:35 PM
10/14/13 08:35 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my old 416 was a solid roller 268/272@ .050 .690 lift 9.76 at 138 in a 3000lb car.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1517594
10/14/13 08:48 PM
10/14/13 08:48 PM
Posts: 3,396 Pa
Hot 340
Pa
just a little question.. but would/could you drive this grind with this cubic inch combo on the street? Behaviour?
[Re: Wedgeman]
#1517595
10/14/13 09:09 PM
10/14/13 09:09 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Mine is 255/266 @.050. Solid roller,but mine is only a 394 ci.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: Hot 340]
#1517596
10/14/13 11:28 PM
10/14/13 11:28 PM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
I'm a little more cubes at 439 but I run a .725 lift 272/276 and it is street driven lots (as much as possible with our short season) and it's street manners are just fine. Actually could have been more radical and been ok yet.
[Re: Wedgeman]
#1517599
10/15/13 12:25 PM
10/15/13 12:25 PM
Posts: 1,178 Indy
FlyFish
Indy
Small solid roller, 248/254 duration, .576/.582 lift, pump gas street car, 3200 lbs, 6.81 @ 99.7 in the 1/8 (high 10.70's in the 1/4).
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: Ian]
#1517603
10/17/13 07:41 PM
10/17/13 07:41 PM
D-50
North, Alabama
solid roller 254/262 0n 107 lc 660 lift .3550 lbs 1.37 60 ft 6.0 113 and [Email]9.57@142[/Email]
You are running NOS also, correct?
[Re: D-50]
#1517607
10/18/13 02:32 AM
10/18/13 02:32 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
correct
[Re: Ian]
#1517608
10/18/13 01:14 PM
10/18/13 01:14 PM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
Old Crane SS solid roller. 276/282 @ .050 and net lift with lash and 1.6 rockers is .698/.714. 408, W5's and 2-750's on a M1 TR. Probably not an ideal cam but it was only $75.00 with only 10 dyno pulls on it.
[Re: Guitar Jones]
#1517609
10/18/13 02:35 PM
10/18/13 02:35 PM
Posts: 35 Minot, ND
darndart
Minot, ND
Just putting the finishing assembly on a 410 for my 73 Dart Sport. It's got a Comp Solid Roller 269/276 @ .050 with .698/.698 w/ 1.6's. Hope to run in the 9.70 range!
73 Dart Sport 340, 410ci, Indy 360-2 230CNC. 72 Demon 340 4-speed 01 Ram Quad Cab 89 Mustang LX Boss 331,C4,HP76mm turbo, FAST EFI 86 Mustang GT 5.0 AOD 82 Capri RS 306, Fox Lake Stage 1 TW, N41, T5,etc.
[Re: darndart]
#1517610
10/18/13 02:39 PM
10/18/13 02:39 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
got a 408 with ported eddy heads, with KB icon 744 pistons and scat I beam rods, Cam is a hughes 264/268 flat tappet with crane gold rockers...
Engine is still on engine stand...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
