Best oil filter #1514302
10/08/13 10:51 PM
10/08/13 10:51 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
My oil filter keeps collasping need the best filter don't want to use a canister type. Heard that wix has a good filter. This is for a stroked 360 that is now a 410. Standard meling pump. Oil pressure is 80 psi and goes to 20psi
Re: Best oil filter [Re: moparmikethree] #1514303
10/09/13 12:05 AM
10/09/13 12:05 AM
yes Wix gets good reviews (on here) regularly. More info on what was happening with your prior ones collapsing
Re: Best oil filter [Re: moparmikethree] #1514304
10/09/13 01:50 AM
10/09/13 01:50 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
The best oil filter is the Donaldson P169071
High Efficiency Industrial.
Cost is roughly three-times that of a Fram PH8A.
You get what you pay for -
Re: Best oil filter [Re: CompSyn] #1514305
10/09/13 02:18 AM
10/09/13 02:18 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i like the Mobil 1 filter, thick canister, seems high quality and they are around $9 on sale.
Re: Best oil filter [Re: ademon] #1514306
10/09/13 02:31 AM
10/09/13 02:31 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I may not buy another WIX after my last oil change (although I did replace one WIX with another). My wife's '02 2.7 has about 68,000 miles. I replaced the filter and oil and a couple of days later the oil light was flickering at idle. I replaced the sending unit which did not fix it so I did the filter again. No more light and it's been almost a month. I'm not sure what I'll buy next, though.
Re: Best oil filter [Re: CompSyn] #1514307
10/09/13 11:41 AM
10/09/13 11:41 AM
The best oil filter is the Donaldson P169071 High Efficiency Industrial.
Who carries it & is it designed for racing or just more for high efficiency filtering?
Re: Best oil filter [Re: RapidRobert] #1514308
10/09/13 12:43 PM
10/09/13 12:43 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Try your local Kaman Industrial supply house or there's places on-line like this - http://www.filterspro.com/detail.cfm?part=1700215
It's not designed for racing per say but it's a heavy-duty constructed oil filter.
That white filter media you see in the pic. That's Donaldson's proprietary Synteq Nano-glass filter media. It flows and filters significantly better than filters constructed with paper media or synthetic/paper blend.
It has a relief valve setting of 8-11 PSI, though it likely has a reduced likelihood of opening because of the superior flow characteristics of the filter media.
Re: Best oil filter [Re: CompSyn] #1514309
10/09/13 12:46 PM
10/09/13 12:46 PM
got it, Thank you
Re: Best oil filter [Re: RapidRobert] #1514310
10/09/13 03:01 PM
10/09/13 03:01 PM
All the race filters bypass oil at a much lower pressure than the standard oil filters do. Do you want filtered oil or not? I do want my oil filtered, not bypassed I found out on a fuel filter that the finer the filter media the harder it is for the pump to suck fuel through it Oil pumps push the oil through the filters so the finer the media the more the interanl restistance to flow in the filter so the internal pressure in the filter will increase making the byapss open sooner and longer When one collasped I would want to know exactly why it collapsed Oil is pushed through the the little holes on the outside edges of the filter and returned to the motor through the big center hole, I can't see or understand how one would collapse I would find out why before running that motor again
Re: Best oil filter [Re: CompSyn] #1514311
10/09/13 03:33 PM
10/09/13 03:33 PM
BDW Online content
BDW  Online Content
When is good, good enough? I'm sure there's a filter on the space shuttle we could adapt. Funny how millions of cars get by. You'd think there is an epidemic of engine failures from all these cheaply made faulty filters.
But hey, it's your money, do what makes you feel good.
Re: Best oil filter [Re: BDW] #1514312
10/09/13 07:36 PM
10/09/13 07:36 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Sure!
How many cubic inches is enough?
How much horsepower is enough?
Subjective questions.
The title of this thread, "Best oil filter".
How much filtering performance is enough?
Again, subjective.
Re: Best oil filter [Re: CompSyn] #1514313
10/09/13 09:04 PM
10/09/13 09:04 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
that "is" exactly the Question....however, to much oil pressure ,to heavy of weight of oil with a a cheap fine paper filter element @ cold temps and or improper bypass systems are the main causes for filter imploding - which was perceived to be a bad filter ... which I think ,led to this question.. I know, I paid my dues to learn.
Re: Best oil filter [Re: CompSyn] #1514314
10/09/13 09:09 PM
10/09/13 09:09 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
CS ....just how much is REALLY NEEDED .... uNless your motor is coming apart ? ... have you ever cut apart a filter .... after one ...two ...three ...even TEN oil changes(after using the same filter) ?
Re: Best oil filter [Re: dOrk !] #1514315
10/09/13 10:06 PM
10/09/13 10:06 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
One could buy the orange can from the big box store for four bucks and the engine will likely outlast the vehicle.
However, the question was not what oil filter will get me by. The question by the OP is "need the best filter"?
I answered the question.
Re: Best oil filter [Re: CompSyn] #1514316
10/10/13 05:10 AM
10/10/13 05:10 AM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Ole CS ...off the deep end again ....
...so you insinuate that these high dollar and uNnecessary neon-lite-up filters are off the deep-end toooooo ?
Re: Best oil filter [Re: CompSyn] #1514317
10/10/13 05:15 AM
10/10/13 05:15 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
I'm glad you did, not that I'm that worried my napa golds aren't good enough, just good to know what is available.
And really, 3Xs the cost of a fram is what, 12-15 bucks?
I can't afford this. mark
Re: Best oil filter [Re: ek3] #1514318
10/10/13 10:00 AM
10/10/13 10:00 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
oil filters were originally there to prolong piston ring life
now oil filters allow hydraulic lifters to continue to operate
journal bearings are much more tolerant of particles in the oil, particularly carbon particles
i have never read a scientific paper that clearly shows whether finely filtered oil is the dominating factor that prolongs piston ring and bore wall wear rates,
or whether it is the film strength of the lube oil that dominates
i have read scientific papers from aircraft engine maker Continental that claimed that coolant temperatures around 200 F keep corrosive chemicals in the exhaust hot enough to be gases rather than hot liquid acids, and that this reduces corrosion and prolongs bore wall life
Re: Best oil filter [Re: 360view] #1514319
10/10/13 02:34 PM
10/10/13 02:34 PM
BDW Online content
BDW  Online Content
mark
I love your signature, apparently you can afford this? Haha
Re: Best oil filter [Re: dOrk !] #1514320
10/10/13 11:44 PM
10/10/13 11:44 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Not at all.
I pay three-times as much for the Donaldson but I use it four-times longer than what a typical entry-level filter would be used.
The Donaldson is a heavy-duty endurance filter. So I'm using it for what it's designed for. Plus I've got a better flowing, better filtering filter throughout the run.
It's what I consider value-per-dollar.
Re: Best oil filter [Re: 360view] #1514321
10/11/13 12:07 AM
10/11/13 12:07 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
An SAE study showed a correlation in engine wear rates between oil filters of varying efficiencies.
For the Diesel study, the results were in terms of Piston Pin, Compression Ring #3, Main Bearings and Rod Bearings.
For the Gasoline engine study, the results were in terms of Upper Main Bearing, Lower Main Bearing, Upper Rod Bearing, and Lower Rod Bearing.
Just because an engine can last 250k with just about any oil filter you throw at it, doesn’t mean it’s optimized.
References: Staley, David R. “Correlating Lube Oil Filtration Efficiencies with Engine Wear,” SAE 881825 - Link HERE
