Re: Best oil filter
[Re: moparmikethree]
#1514303
10/09/13 12:05 AM
10/09/13 12:05 AM
RapidRobert
yes Wix gets good reviews (on here) regularly. More info on what was happening with your prior ones collapsing
Re: Best oil filter
#1514304
10/09/13 01:50 AM
10/09/13 01:50 AM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
The best oil filter is the Donaldson P169071 High Efficiency Industrial. Cost is roughly three-times that of a Fram PH8A. You get what you pay for -
Re: Best oil filter
[Re: RapidRobert]
#1514308
10/09/13 12:43 PM
10/09/13 12:43 PM
CompSyn
Pacific NW USA
Who carries it & is it designed for racing or just more for high efficiency filtering?
Try your local Kaman Industrial supply house or there's places on-line like this - http://www.filterspro.com/detail.cfm?part=1700215
It's not designed for racing per say but it's a heavy-duty constructed oil filter.
That white filter media you see in the pic. That's Donaldson's proprietary Synteq Nano-glass filter media. It flows and filters significantly better than filters constructed with paper media or synthetic/paper blend.
It has a relief valve setting of 8-11 PSI, though it likely has a reduced likelihood of opening because of the superior flow characteristics of the filter media.
Re: Best oil filter
[Re: CompSyn]
#1514311
10/09/13 03:33 PM
10/09/13 03:33 PM
Posts: 4,726 Florida
BDW
When is good, good enough? I'm sure there's a filter on the space shuttle we could adapt. Funny how millions of cars get by. You'd think there is an epidemic of engine failures from all these cheaply made faulty filters.
But hey, it's your money, do what makes you feel good.
Re: Best oil filter
[Re: BDW]
#1514312
10/09/13 07:36 PM
10/09/13 07:36 PM
CompSyn
Pacific NW USA
Sure!
How many cubic inches is enough?
How much horsepower is enough?
Subjective questions.
The title of this thread, "Best oil filter".
How much filtering performance is enough?
Again, subjective.
Re: Best oil filter
[Re: CompSyn]
#1514314
10/09/13 09:09 PM
10/09/13 09:09 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
CS ....just how much is REALLY NEEDED .... uNless your motor is coming apart ? ... have you ever cut apart a filter .... after one ...two ...three ...even TEN oil changes(after using the same filter) ?
Re: Best oil filter
[Re: dOrk !]
#1514315
10/09/13 10:06 PM
10/09/13 10:06 PM
CompSyn
Pacific NW USA
One could buy the orange can from the big box store for four bucks and the engine will likely outlast the vehicle.
However, the question was not what oil filter will get me by. The question by the OP is "need the best filter"?
I answered the question.
Re: Best oil filter
[Re: dOrk !]
#1514320
10/10/13 11:44 PM
10/10/13 11:44 PM
CompSyn
Pacific NW USA
...so you insinuate that these high dollar and uNnecessary neon-lite-up filters are off the deep-end toooooo ?
Not at all.
I pay three-times as much for the Donaldson but I use it four-times longer than what a typical entry-level filter would be used.
The Donaldson is a heavy-duty endurance filter. So I'm using it for what it's designed for. Plus I've got a better flowing, better filtering filter throughout the run.
It's what I consider value-per-dollar.
Re: Best oil filter
[Re: 360view]
#1514321
10/11/13 12:07 AM
10/11/13 12:07 AM
CompSyn
Pacific NW USA
oil filters were originally there to prolong piston ring life
now oil filters allow hydraulic lifters to continue to operate
journal bearings are much more tolerant of particles in the oil, particularly carbon particles
i have never read a scientific paper that clearly shows whether finely filtered oil is the dominating factor that prolongs piston ring and bore wall wear rates, or whether it is the film strength of the lube oil that dominates
i have read scientific papers from aircraft engine maker Continental that claimed that coolant temperatures around 200 F keep corrosive chemicals in the exhaust hot enough to be gases rather than hot liquid acids, and that this reduces corrosion and prolongs bore wall life
An SAE study showed a correlation in engine wear rates between oil filters of varying efficiencies.
For the Diesel study, the results were in terms of Piston Pin, Compression Ring #3, Main Bearings and Rod Bearings.
For the Gasoline engine study, the results were in terms of Upper Main Bearing, Lower Main Bearing, Upper Rod Bearing, and Lower Rod Bearing.
Just because an engine can last 250k with just about any oil filter you throw at it, doesn’t mean it’s optimized.
References: Staley, David R. “Correlating Lube Oil Filtration Efficiencies with Engine Wear,” SAE 881825 - Link HERE
