Re: 42LE Question
[Re: 135sohc]
#1498272
09/08/13 09:30 PM
09/08/13 09:30 PM
Posts: 276 Temecula, Ca.
zzyzxpat
Temecula, Ca.
Why? If it is time to change the fluid, you need to change the filter as well.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 42LE Question
[Re: 135sohc]
#1498274
09/09/13 01:40 PM
09/09/13 01:40 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Adding a drain plug the transmission pan on the car. Its the 42LE (LH car transmission). When we last had the pan off I forgot to take any pictures of the inside. I dont want to run into clearance issues with the nut/drain plug on the valve body. I understand this is a long shot at best asking but if anyone here has added a drain plug to the 42LE and has first hand knowledge of any clearance issues I would love to hear from you.
Thank you.
The clearance is tight...They have a wide and deep plastic filter that takes up considerable room..You can put it in the corner, I suppose. ...Id have to see what type of plug you are using..BTW if you arent going to weld the plug bung in the pan, you can just about guarantee that its going to leak. Those types that use the plastic washer just never seal. You also have to consider that the pan has ribs, so that would preclude putting pne of those plugs there...
IMO, its a waste of time..Lock up transmissions rarely need fluid service and you cant get near 100 % of the fluid out of it just by dropping a pan, so what did you really accomplish?
Just my as a seasoned trans guy.
MB
