42LE Question #1498271
09/08/13 03:25 PM
09/08/13 03:25 PM
SoMd, USA
135sohc Offline OP
135sohc  Offline OP
SoMd, USA
Adding a drain plug the transmission pan on the car. Its the 42LE (LH car transmission). When we last had the pan off I forgot to take any pictures of the inside. I dont want to run into clearance issues with the nut/drain plug on the valve body. I understand this is a long shot at best asking but if anyone here has added a drain plug to the 42LE and has first hand knowledge of any clearance issues I would love to hear from you.
Thank you.
Re: 42LE Question [Re: 135sohc] #1498272
09/08/13 09:30 PM
09/08/13 09:30 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
Why? If it is time to change the fluid, you need to change the filter as well.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: 42LE Question [Re: zzyzxpat] #1498273
09/09/13 01:33 PM
09/09/13 01:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Pat
It's far more convenient to have a drain plug to dump the fluid before you pull the pan.
- Stu Harmon
Re: 42LE Question [Re: 135sohc] #1498274
09/09/13 01:40 PM
09/09/13 01:40 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Thank you.
The clearance is tight...They have a wide and deep plastic filter that takes up considerable room..You can put it in the corner, I suppose. ...Id have to see what type of plug you are using..BTW if you arent going to weld the plug bung in the pan, you can just about guarantee that its going to leak. Those types that use the plastic washer just never seal. You also have to consider that the pan has ribs, so that would preclude putting pne of those plugs there...
IMO, its a waste of time..Lock up transmissions rarely need fluid service and you cant get near 100 % of the fluid out of it just by dropping a pan, so what did you really accomplish?
Just my as a seasoned trans guy.
MB
