Adding a drain plug the transmission pan on the car. Its the 42LE (LH car transmission). When we last had the pan off I forgot to take any pictures of the inside. I dont want to run into clearance issues with the nut/drain plug on the valve body. I understand this is a long shot at best asking but if anyone here has added a drain plug to the 42LE and has first hand knowledge of any clearance issues I would love to hear from you.
Thank you.
