Re: Meth injection..who runs it?
[Re: Hot 340]
#1494810
09/02/13 10:25 AM
09/02/13 10:25 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Looking for info on meth injection. Where is methanol acquired? Cost effective? How much is used per gallon of gasoline roughly? How about suggested kits? We are going to be putting a new bullet in my brother's car soon and wondering about this option for a high comprsssion street shortblock we have laying here for it. Sorry for all the questions..I know nothing about it.
For a street build I would run E-85... if its in your area... most of the time its way easier to get... do you plan on driving it in cold weather ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1494811
09/02/13 10:31 AM
09/02/13 10:31 AM
Posts: 3,396 Pa
Hot 340
Pa
E85 is unfortunately out of the question right now as no pumps close by. As for cold driving, maybe some cool fall weather but no winter driving ect..
[Re: MR_P_BODY]
#1494814
09/02/13 10:46 AM
09/02/13 10:46 AM
Posts: 3,396 Pa
Hot 340
Pa
In cool/cold weather the alky type fuels dont like to fire up(basically below 45*) so a gas system is used to get it fired and get a bit of temp into the engine then change over to the alky.... just as a rule of thumb you use 2X the amount for alky that you did for gas.. you might want to look at Rons Toilet as a site for info and part... they sell lots of injection stuff http://www.ronsfuel.com/killerrons.cfm
So Im guessing by your wording its not a system which supplements a standard gasoline system while running..which is what I was thinking it was.
[Re: Hot 340]
#1494818
09/02/13 11:54 AM
09/02/13 11:54 AM
MR_P_BODY
Are you talking about a ADDED system so he can run gas then spray in meth to cool the intake charge and add octane... OR a complete meth injection system ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1494820
09/02/13 12:20 PM
09/02/13 12:20 PM
He is talking about the use of a water and meth type kit Mike.
[Re: ]
#1494821
09/02/13 12:45 PM
09/02/13 12:45 PM
Posts: 3,396 Pa
Hot 340
Pa
Yes, im talking about the add on kits...sorry.
[Re: Mr.Yuck]
#1494822
09/02/13 12:46 PM
09/02/13 12:46 PM
Posts: 3,396 Pa
Hot 340
Pa
I'm running the snow performance meth/H2O kit. 11.2:1 440-6, no issues. I run 93 timing is set at 37* and I have no issues. Mine runs through a plate under the primary carb and it activated when the vaccum drops to 0...
How much of it does it use per gallon of gas and is it hard to get?
[Re: Hot 340]
#1494824
09/02/13 04:45 PM
09/02/13 04:45 PM
You can run wiper fluid in the kit and they last quite awhile apparently.
[Re: Hot 340]
#1494825
09/02/13 04:51 PM
09/02/13 04:51 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
It doesn't usde much at all, maybe 2.5"'s a day at the track. And it's washer fluid... pretty easy to find. It only fogs when the engine is under a load. I don't even "arm" it until I get to the track..or if I'm going to get on it.
[Re: Mr.Yuck]
#1494827
09/02/13 05:11 PM
09/02/13 05:11 PM
1974Cuda360
I run meth in my supercharged 408. I am using a kit from AIS. A few year ago I was dyno testing the engine and there was a 70 HP difference when meth was used. I couldn't believe it. I actually bought the kit because it was easier to install than an intercooler. The added octane is also a big plus considering windshield washer fluid costs much less than race fuel.
[Re: 1974Cuda360]
#1494828
09/02/13 05:34 PM
09/02/13 05:34 PM
Mr.Yuck
Brookeville, Md
..... The added octane is also a big plus considering windshield washer fluid costs much less than race fuel.
ding ding ding WINNER....
