Meth injection..who runs it? #1494809
09/02/13 10:13 AM
09/02/13 10:13 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Looking for info on meth injection. Where is methanol acquired? Cost effective? How much is used per gallon of gasoline roughly? How about suggested kits? We are going to be putting a new bullet in my brother's car soon and wondering about this option for a high comprsssion street shortblock we have laying here for it. Sorry for all the questions..I know nothing about it.
Re: Meth injection..who runs it? [Re: Hot 340] #1494810
09/02/13 10:25 AM
09/02/13 10:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
For a street build I would run E-85... if its in your
area... most of the time its way easier to get...
do you plan on driving it in cold weather
Re: Meth injection..who runs it? [Re: MR_P_BODY] #1494811
09/02/13 10:31 AM
09/02/13 10:31 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
E85 is unfortunately out of the question right now as no pumps close by. As for cold driving, maybe some cool fall weather but no winter driving ect..
Re: Meth injection..who runs it? [Re: Hot 340] #1494812
09/02/13 10:41 AM
09/02/13 10:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
In cool/cold weather the alky type fuels dont like to
fire up(basically below 45*) so a gas system is used
to get it fired and get a bit of temp into the engine
then change over to the alky.... just as a rule of thumb
you use 2X the amount for alky that you did for gas..
you might want to look at Rons Toilet as a site for info
and part... they sell lots of injection stuff
http://www.ronsfuel.com/killerrons.cfm
Re: Meth injection..who runs it? [Re: Hot 340] #1494813
09/02/13 10:43 AM
09/02/13 10:43 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Check out snow performance.
Re: Meth injection..who runs it? [Re: MR_P_BODY] #1494814
09/02/13 10:46 AM
09/02/13 10:46 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
So Im guessing by your wording its not a system which supplements a standard gasoline system while running..which is what I was thinking it was.
Re: Meth injection..who runs it? [Re: Hot 340] #1494815
09/02/13 10:50 AM
09/02/13 10:50 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have been looking at the AIS & Snow systems.Just looks too good to be true
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Meth injection..who runs it? [Re: Hot 340] #1494816
09/02/13 10:55 AM
09/02/13 10:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Meth on the street isnt what I call street friendly
but it can work... but not with a stock fuel system..
you would really need a new tank, lines, pump and
then the injection itself(throttle body or injector
type system)... then getting meth on the street isnt
gonna happen.. that would be harder to get than E-85
Re: Meth injection..who runs it? [Re: MR_P_BODY] #1494817
09/02/13 11:47 AM
09/02/13 11:47 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Buddy of mine runs meth injection on his 89 blown mustang. His system is from devilsown performance- about half the cost of snow performance, same quality, and I believe more adjustability. He hardly goes through any of it as you program when you want it to come in. I can't see you needing high amounts of it even in a high compression street car unless you are giving it a lot. For just cruising around, I would assume pump gas with the right camshaft to bleed off the compression would work ok
Re: Meth injection..who runs it? [Re: Hot 340] #1494818
09/02/13 11:54 AM
09/02/13 11:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you talking about a ADDED system so he can run
gas then spray in meth to cool the intake charge
and add octane... OR a complete meth injection system
Re: Meth injection..who runs it? [Re: mshred] #1494819
09/02/13 11:54 AM
09/02/13 11:54 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'm running the snow performance meth/H2O kit. 11.2:1 440-6, no issues. I run 93 timing is set at 37* and I have no issues. Mine runs through a plate under the primary carb and it activated when the vaccum drops to 0...
Coming soon!!!!
Re: Meth injection..who runs it? [Re: MR_P_BODY] #1494820
09/02/13 12:20 PM
09/02/13 12:20 PM
He is talking about the use of a water and meth type kit Mike.
Re: Meth injection..who runs it? [Re: ] #1494821
09/02/13 12:45 PM
09/02/13 12:45 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Yes, im talking about the add on kits...sorry.
Re: Meth injection..who runs it? [Re: Mr.Yuck] #1494822
09/02/13 12:46 PM
09/02/13 12:46 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
How much of it does it use per gallon of gas and is it hard to get?
Re: Meth injection..who runs it? [Re: rickraw] #1494823
09/02/13 02:55 PM
09/02/13 02:55 PM
Az
Crizila Offline
Crizila  Offline
Az
That's what I run with my blower motor. IMO, one of the best systems out there. Lots of options to choose from and very tunable for almost any application.
Fastest 300
Re: Meth injection..who runs it? [Re: Hot 340] #1494824
09/02/13 04:45 PM
09/02/13 04:45 PM
You can run wiper fluid in the kit and they last quite awhile apparently.
Re: Meth injection..who runs it? [Re: Hot 340] #1494825
09/02/13 04:51 PM
09/02/13 04:51 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
It doesn't usde much at all, maybe 2.5"'s a day at the track. And it's washer fluid... pretty easy to find. It only fogs when the engine is under a load. I don't even "arm" it until I get to the track..or if I'm going to get on it.
Re: Meth injection..who runs it? [Re: Crizila] #1494826
09/02/13 05:05 PM
09/02/13 05:05 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
kind of off topic, but are you using a 6 or 10 groove pulley system on your supercharger?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Meth injection..who runs it? [Re: Mr.Yuck] #1494827
09/02/13 05:11 PM
09/02/13 05:11 PM
1974Cuda360 Offline
1974Cuda360  Offline
I run meth in my supercharged 408. I am using a kit from AIS. A few year ago I was dyno testing the engine and there was a 70 HP difference when meth was used. I couldn't believe it. I actually bought the kit because it was easier to install than an intercooler. The added octane is also a big plus considering windshield washer fluid costs much less than race fuel.
Re: Meth injection..who runs it? [Re: 1974Cuda360] #1494828
09/02/13 05:34 PM
09/02/13 05:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
..... The added octane is also a big plus considering windshield washer fluid costs much less than race fuel.
ding ding ding WINNER....
