Re: Lowest gears for 8 3/4?
[Re: Kelob_pie]
#148133
11/10/08 11:10 AM
11/10/08 11:10 AM
RapidRobert
either 2.76 or 2.45 I forget which but probably 2.76 & 5.57 on the other end
[Re: RapidRobert]
#148134
11/10/08 12:39 PM
11/10/08 12:39 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Numericaly high are low gears, and vice versa. I think I've seen as low as 5.57, never really looked hard tho. High gear would be 2.76s, I've never seen higher than that if they exist.
[Re: moper]
#148135
11/10/08 03:52 PM
11/10/08 03:52 PM
Posts: 15,487 Florida
scratchnfotraction
I had a 7 1/4 rear axle with 4" wbp,open dff,in a 170 cu in - /6 68 Dart with stock 13" rims with a 1.76 gear only ones I ever seen dint last long with the 318 though!shure would fly on the open road too,just didnt stop with 9" drums all the way around try dr diff or randy r&p
[Re: scratchnfotraction]
#148136
11/10/08 08:29 PM
11/10/08 08:29 PM
Posts: 8,846 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i have a 8 3/4 with a set of 6.14,s lowest iv ever found
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#148137
11/10/08 08:58 PM
11/10/08 08:58 PM
RapidRobert
I thought 5.57's were the lowest! What make are these? any pics possible. More details please. I needed a lower set for my circle burner & 5.57 was all I could locate. I ended up using a 9" furd with 6.20's
[Re: moper]
#148139
11/10/08 10:45 PM
11/10/08 10:45 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
No, NO .... ...on ALL counts !
A LOW gear ...is a SHORT gear. A high gear is tall, steep and BIGGER. And the steepest gear ever offered for the 8 3/4 was a 6.17. And the SHORTEST would be either a 2.41 or 2.45.
NEVER seen one of those though.
[Re: dOrk !]
#148141
11/11/08 02:09 AM
11/11/08 02:09 AM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
I think you've got it backwards there.
[Re: Kelob_pie]
#148142
11/11/08 03:53 AM
11/11/08 03:53 AM
Posts: 214 Hamburg / Germany
Den300
Hamburg / Germany
i think the 2.42 oder 2.45 or 2.4x what ever came in the diplomat or cordoba!?
Hamburg/Germany
69 Chrysler 300 446cui Dual Quad 12.64 @ 110.7
[Re: mopowers]
#148144
11/11/08 08:45 AM
11/11/08 08:45 AM
i know he does.
A low gear is a steep gear is a high number (like 4.11's)
a high gear is a tall gear is a low number (like 2.76)
#148145
11/11/08 01:28 PM
11/11/08 01:28 PM
dOrk !
Florida STAYcation
i know he does.
Low equals HIGH ?
And HIGH equals LOW ??
I do KNOW that you two are HIGH on something !!
[Re: dOrk !]
#148146
11/11/08 01:32 PM
11/11/08 01:32 PM
when you put it in low, you drop it into 1 which is the highest numerical gear in the tranny. the lower the gear, the more umpf you get.
do a google on 'what is low gear' or low gear ratio
[Re: dOrk !]
#148147
11/11/08 08:08 PM
11/11/08 08:08 PM
mopowers
Sac, CA
i know he does.
Low equals HIGH ?
I'm having trouble figuring out if you're serious or not.
[Re: mopowers]
#148148
11/12/08 11:00 AM
11/12/08 11:00 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
i know who made my 6.14,s i bought a old dart race car 340 4 speed it had a narrowed rear and set up for 1/8 mile i devided the gears and laughed and had a couple of buddys do the same thay laughed i got ahold of the guy that done the car he comfirmed i kept then in the car for a summer but never drove it out of town i still got them on the pig but not really looking to sell them
[Re: RapidRobert]
#148150
11/12/08 01:37 PM
11/12/08 01:37 PM
moper
Columbia, CT
Yes 440, you have it backwards... at least in terms of a car. It's easy to get confused by it. In automotive circles, gear ratio and the description are tweaked...lol. The higher the torque multiplication, the lower the gear in terms of transmission gears you're in. First is a "lower" gear than 2nd..etc etc etc. This is carried over to the rear axle too. You're technically right with a lower gear ratio being 3.23:1 vs 5.13:1 because there's less turns of the drive gear vs the driven gear. But in automotive circles, it's not a standard way of describing things.
[Re: Junky]
#148157
11/12/08 11:59 PM
11/12/08 11:59 PM
Posts: 196 out front
jerrya
Comin to a Labor Day Telethon
out front
Ain't no valley LOW, ain't no mountain HIGH
Man does not plan to fail... he fails to plan
[Re: jerrya]
#148158
11/13/08 12:08 AM
11/13/08 12:08 AM
RapidRobert
It ain't never gonna end. I'll end up running a thermoquad before it's all said & done.
[Re: RapidRobert]
#148159
11/13/08 12:06 PM
11/13/08 12:06 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
its simple...do you take off in low gear or take off in high? in a normal 4 speed 4th is 1-1 but first is way lower and has a higher # ratio
[Re: DoctorDiff]
#148162
11/13/08 12:40 PM
11/13/08 12:40 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I have a 742 casting/3.42/Detroit Locker third-member. It is a factory built unit with a 1964 date code. It supposedly came from Petty Enterprises.
Assy, Differential & Carrier (large stem pinion) -Part number PE-342R in the 74 PE catalog.
[Re: autoxcuda]
#148163
11/13/08 04:44 PM
11/13/08 04:44 PM
RapidRobert
I googled them & saw PE but couldn't find a redirect for any parts for sale
[Re: RapidRobert]
#148164
11/13/08 05:41 PM
11/13/08 05:41 PM
autoxcuda
So Cal
The catalog I quoted from was from 1974. I don't think they have or wish to sell any of that stuff. That was 30 years ago.
[Re: RapidRobert]
#148169
11/14/08 09:09 AM
11/14/08 09:09 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok how do i tell who made them?
[Re: toplescuda]
#148170
11/14/08 09:39 AM
11/14/08 09:39 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
ok i went and dug the 500 pound chunk out of the shed here is all i found its a 742 case with a big on the side of it has 43 gears on ring and 7 on the penion(sp?) also has like some kind of bright shinny line across the ring with 184 and looks to be a j etched into it then 5010 h then looks like a apple shape then 7 r 8620 what the heck does all that mean? i took these gears out cause the penion nut backed off and thay strated to make a houling sound one night so next day i swaped them out
[Re: toplescuda]
#148171
11/14/08 10:17 AM
11/14/08 10:17 AM
RapidRobert
43 teeth & 7 teeth is certainly 6.14's. The #'s dont ring a bell. A damaged/howling set is no sweat on a circle burner because the open exhausts from 20 cars is deafening.
#148173
11/14/08 10:38 AM
11/14/08 10:38 AM
RapidRobert
It does take a different mindset because you'd think that'd be WAY too low but it's perfect(.4 mile high banked dirt track) 360 9-1 CR 2bbl by class rules & at the end of the straights it is still pulling strong at over 6400. Those Hughes cams are awesome.
#148175
11/14/08 11:04 AM
11/14/08 11:04 AM
RapidRobert
yeah I thought it'd be laying down at that point. It's one of Daves oval track grinds I don't know the # right offhand but he definitely has my business
[Re: John_Kunkel]
#148178
11/15/08 12:26 AM
11/15/08 12:26 AM
Posts: 1,263 Southwestern Ontario Canada
racealittle
I swear I have a 2.72 gearset in a 742 housing from a very early '60's Chrysler. The older pre '60's cars had some unique gear choices, didn't they? I've seen some odd ratios (example 3.36).
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
[Re: RapidRobert]
#148183
11/15/08 01:24 AM
11/15/08 01:24 AM
racealittle
Robert, I could send you a picture of it, but there are alot of mopar parts in the way, getting to it. Do you really want me to dig it out? The numbers are stamped in the gear set. Every time I've had to dig through that area of the garage, I look at the ratio because I too, find it hard to beleive.
[Re: racealittle]
#148184
11/15/08 01:31 AM
11/15/08 01:31 AM
RapidRobert
No bro please dont & in no way should my ramblings ever be construed as fact or to be taken as motivation to do something that is not absolutely neccessary.
