Page 1 of 3 1 2 3
Lowest gears for 8 3/4? #148132
11/10/08 11:06 AM
11/10/08 11:06 AM
Kewaskum, WI
K
Kelob_pie Offline OP
K
Kewaskum, WI
What are the lowest gears you can get for an 8 3/4? 2.76's? Thanks in advance!
Re: Lowest gears for 8 3/4? [Re: Kelob_pie] #148133
11/10/08 11:10 AM
11/10/08 11:10 AM
either 2.76 or 2.45 I forget which but probably 2.76 & 5.57 on the other end
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148134
11/10/08 12:39 PM
11/10/08 12:39 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Numericaly high are low gears, and vice versa. I think I've seen as low as 5.57, never really looked hard tho. High gear would be 2.76s, I've never seen higher than that if they exist.
Re: Lowest gears for 8 3/4? [Re: moper] #148135
11/10/08 03:52 PM
11/10/08 03:52 PM
scratchnfotraction Offline
I had a 7 1/4 rear axle with 4" wbp,open dff,in a 170 cu in - /6 68 Dart with stock 13" rims with a 1.76 gear
only ones I ever seen
dint last long with the 318 though!shure would fly on the open road too,just didnt stop with 9" drums all the way around
try dr diff or randy r&p
Re: Lowest gears for 8 3/4? [Re: scratchnfotraction] #148136
11/10/08 08:29 PM
11/10/08 08:29 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i have a 8 3/4 with a set of 6.14,s lowest iv ever found
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Lowest gears for 8 3/4? [Re: toplescuda] #148137
11/10/08 08:58 PM
11/10/08 08:58 PM
I thought 5.57's were the lowest! What make are these? any pics possible. More details please. I needed a lower set for my circle burner & 5.57 was all I could locate. I ended up using a 9" furd with 6.20's
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148138
11/10/08 10:31 PM
11/10/08 10:31 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
depends on what pumpkin, 489? 742's? etc
Re: Lowest gears for 8 3/4? [Re: moper] #148139
11/10/08 10:45 PM
11/10/08 10:45 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
No, NO .... ...on ALL counts !
A LOW gear ...is a SHORT gear. A high gear is tall, steep and BIGGER. And the steepest gear ever offered for the 8 3/4 was a 6.17. And the SHORTEST would be either a 2.41 or 2.45.
NEVER seen one of those though.
Re: Lowest gears for 8 3/4? [Re: dOoC] #148140
11/10/08 11:31 PM
11/10/08 11:31 PM
WHO sells em(the 6.14)
Re: Lowest gears for 8 3/4? [Re: dOoC] #148141
11/11/08 02:09 AM
11/11/08 02:09 AM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I think you've got it backwards there.
Re: Lowest gears for 8 3/4? [Re: Kelob_pie] #148142
11/11/08 03:53 AM
11/11/08 03:53 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
i think the 2.42 oder 2.45 or 2.4x what ever came
in the diplomat or cordoba!?
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Lowest gears for 8 3/4? [Re: Den300] #148143
11/11/08 07:16 AM
11/11/08 07:16 AM
i think the 2.42 oder 2.45 or 2.4x what ever came in the diplomat or cordoba!?
2.45 I believe in an 8&1/4
Re: Lowest gears for 8 3/4? [Re: mopowers] #148144
11/11/08 08:45 AM
11/11/08 08:45 AM
i know he does.
A low gear is a steep gear is a high number (like 4.11's)
a high gear is a tall gear is a low number (like 2.76)
Re: Lowest gears for 8 3/4? #148145
11/11/08 01:28 PM
11/11/08 01:28 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
i know he does.
Low equals HIGH ?
And HIGH equals LOW ??
I do KNOW that you two are HIGH on something !!
Re: Lowest gears for 8 3/4? [Re: dOoC] #148146
11/11/08 01:32 PM
11/11/08 01:32 PM
when you put it in low, you drop it into 1 which is the highest numerical gear in the tranny. the lower the gear, the more umpf you get.
do a google on 'what is low gear' or low gear ratio
Re: Lowest gears for 8 3/4? [Re: dOoC] #148147
11/11/08 08:08 PM
11/11/08 08:08 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
i know he does.
Low equals HIGH ?
I'm having trouble figuring out if you're serious or not.
Re: Lowest gears for 8 3/4? [Re: mopowers] #148148
11/12/08 11:00 AM
11/12/08 11:00 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i know who made my 6.14,s i bought a old dart race car 340 4 speed it had a narrowed rear and set up for 1/8 mile i devided the gears and laughed and had a couple of buddys do the same thay laughed i got ahold of the guy that done the car he comfirmed i kept then in the car for a summer but never drove it out of town
i still got them on the pig but not really looking to sell them
1971 charger
Re: Lowest gears for 8 3/4? [Re: toplescuda] #148149
11/12/08 11:07 AM
11/12/08 11:07 AM
Ralph who made em. Maybe they are still available & I can get a set
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148150
11/12/08 01:37 PM
11/12/08 01:37 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Yes 440, you have it backwards... at least in terms of a car. It's easy to get confused by it. In automotive circles, gear ratio and the description are tweaked...lol. The higher the torque multiplication, the lower the gear in terms of transmission gears you're in. First is a "lower" gear than 2nd..etc etc etc. This is carried over to the rear axle too. You're technically right with a lower gear ratio being 3.23:1 vs 5.13:1 because there's less turns of the drive gear vs the driven gear. But in automotive circles, it's not a standard way of describing things.
Re: Lowest gears for 8 3/4? [Re: RapidRobert] #148151
11/12/08 09:45 PM
11/12/08 09:45 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i have no clue il try to go out tomarrow in the shed and see if i can find something i took them out of my pro street cuda and put a set of 3.55 in it(all i had)sooner or later im gonna put a set of 4.56 or 4.88,s back in it got a 31x18.5 radial on it now so it need some gear,s
1971 charger
Page 1 of 3 1 2 3
