Transporting a Truck Cab in the bed of a pick up truck? #1476712
07/30/13 11:43 PM
07/30/13 11:43 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
Has anyone ever transported a pick up truck cab shell in the bed of a pick up and if so, how well did it fit??
For the 1994 - 2002 era truck.....will a 1994 - 2002 cab shell fit in the bed of the this same era of truck?
The reason I ask is that we need to transport a cab and do not have enough trailer room left to set it on and I am wondering how far down (depth) in the bed will the truck cab fit in the bed??
Thanks!!!
"Fat drunk and stupid is no way to go through life son......"
http://www.youtube.com/watch?v=bK-Dqj4fHmM
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: E-Ticket] #1476713
07/31/13 12:43 AM
07/31/13 12:43 AM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
Have not but want to see pics when you try it.. Good luck..
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: Mopar2DBone] #1476714
07/31/13 12:45 AM
07/31/13 12:45 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
It works in the 80s beds..somebody posted pics of a cab in a bed just awhile back..
I am truckless..
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: 340SHORTY] #1476715
07/31/13 09:41 AM
07/31/13 09:41 AM
scratchnfotraction Offline
how much body damage to the cab do you want?
I hauled a cab on a small 8x10 trailer. 6 hrs of body work to fix the crease in the cab corners.
add a hitch and tow a trailer behind a trailer.
the wheel tubs are going to tilt the cab anyway you put it and the cab is going to get some dents by the time you man handle it on/off with a lift or not.
NOW a truck bed is another story, I have fliped a long bed upside down on another long bed truck and used c-clamps to hold the bed rails together for a 150 mile ride at 55 mph.
maybe some 4x4 or 2x6 across the bed rails and sit the cab on top of the bed rails and strap it off.
good luck
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: scratchnfotraction] #1476716
07/31/13 12:44 PM
07/31/13 12:44 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I have hauled a mid 80s cab in a mid 80s shortbed by stacking pallets 2 high front and rear of the bed for the rockers to sit on. It didnt have doors or glass, strapped thru windshield and rear window openings. It rode fine.
I loaded it with a biig forklift, forks were long enough to go thru both front and rear pallets.
Unloaded it with a hoist.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: E-Ticket] #1476717
07/31/13 08:38 PM
07/31/13 08:38 PM
Lehigh Acres, Florida
rickstershemi Offline
Thanks!!!
Gonna be a great u-tube vid.....please let us know when it's up
A trailer with some dunnage to support the cab would be my choice
Rickster
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: rickstershemi] #1476718
07/31/13 09:59 PM
07/31/13 09:59 PM
East Texas
Mopar2DBone Offline
Mopar2DBone  Offline
East Texas
They are a lot heavier than I thought they where..
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: Mopar2DBone] #1476719
08/02/13 11:48 AM
08/02/13 11:48 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
The fellow I bout mine from said they (70's&80's) fit right in there.
I wasn't sure, so I brought some wood to boost it. It sure looked like it would fit, but the wood was already there.
Not sure of newer years,though. I wouldn't think they would be that much longer, front to rear. I guess you could just jack it up like I did. Traveled two hours at 60 mph with no trouble. The guy that loaded it thought it was funny enough to take a picture to show his brother.
Both are members here. Maybe one of em will see this and chime in.
I have mechanical Aptitude.
I can screw up anything.
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: rickstershemi] #1476720
08/02/13 11:53 AM
08/02/13 11:53 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Rickster
Already said the trailer was full.
Put the dunnage in the truck bed, if there is a fitment problem..
I would like to see the whole deal, once loaded.
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: bboogieart] #1476721
08/02/13 01:21 PM
08/02/13 01:21 PM
Coeur d Alene, Idaho
jimbob101 Offline
jimbob101  Offline
Yep! That's the way to do it with the 70s and 80s cabs in an 8ft bed! Running two pallets end to end, screwed together the cab will fit inbetween the wheel wells, and the tran tunnel hump goes rite over the wheelwell, so don't really need any dunnage underneath. Using 8ft fork extensions to run through the pallets works great. 6ft bed hauling, you have to raise it up just a bit..and tailgate down.
I bet the 94 cabs would be pretty similar, if not, raise it will some 4x4 or 6x6s or whatever.
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: jimbob101] #1476722
08/02/13 01:29 PM
08/02/13 01:29 PM
jimbob101 Offline
jimbob101  Offline
If you're creative with a short bed.. : )
-J
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: jimbob101] #1476723
08/02/13 01:29 PM
08/02/13 01:29 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Right on jimbob got an 80's bed for me?
Tell the truth, you get those pallets from N.E.W. plastics right? I used to work for them in the Coleman plant and the one I got from you looks exactly the same as the ones I had to build...
Works like a dream. The 6X6s didn't hurt either. Just a little taller.
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: bboogieart] #1476724
08/02/13 01:34 PM
08/02/13 01:34 PM
jimbob101 Offline
jimbob101  Offline
Yes I do! There is a 80s bed one with and one without trim package at my bros house, what are you looking for? Both have no rust out on them, some surface rust from peeling paint! The 80s box made into a trailer listed above is available with the trim in Wisconsin!
Geez, pallets come from Lignetics Presto Logs in Sandpoint, Idaho, got a stack of them and they give them away for freeee!! Like the hardwood ones! : )
-J
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: jimbob101] #1476725
08/02/13 01:38 PM
08/02/13 01:38 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Ha ha I thought the picture was your brothers place.
There is an NEW plant right down the road from him. I worked at the other one.
PM sent.
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: scratchnfotraction] #1476726
08/02/13 01:49 PM
08/02/13 01:49 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Not so my friend.
You can see the cab is in the truck. As jimbob101 said it fit right in there with a little something under it. As I said I traveled for 2 hours at 60 with no issues. I used the big ratchet straps to hold it in place.
I unloaded my cab with a cheap engine hoist with no damage. Bolted it to the floor through the mounting holes with plates on top and bottom. Didn't even take the doors off. Went right in through the passenger door. It looked a little scary way up in the air but I drove the truck out from underneath and rolled the dolly it is still sitting on, under it. Maybe I would have messed it up if I knew it couldn't be done.
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: bboogieart] #1476727
08/03/13 04:07 AM
08/03/13 04:07 AM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
I wish this one would be that easy but one thing I forgot to mention is that the truck cab I am transporting is a "Quad Cab" so it wont be quite as easy as a standard cab. I may be taking a car hauler down there to pick this up and will still have room to load the car behind the cab........"barely".......
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: E-Ticket] #1476728
08/03/13 08:03 AM
08/03/13 08:03 AM
jimbob101 Offline
jimbob101  Offline
Nope, you aren't gonna haul a quad cab in the back unless it's completely above the bed sides! I looked at doing a 90s extended cab in the back, aint gonna happen. Trailer it is!
-J
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: jimbob101] #1476729
08/03/13 02:01 PM
08/03/13 02:01 PM
Louisville, KY
E
E-Ticket Offline OP
E-Ticket  Offline OP
E
Louisville, KY
I pretty much have come to the realization that it will either have to ride pretty much at bed rail height or on a trailer.......
Thanks to all!!
Re: Transporting a Truck Cab in the bed of a pick up truck? [Re: E-Ticket] #1476730
08/03/13 03:10 PM
08/03/13 03:10 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
yep that changes everything, huh?
AS for putting the cab on the trailer first. I would consider the weight of the car versus the cab. Should probably put the car on front and the cab in back.
