Re: Transporting a Truck Cab in the bed of a pick up truck?
[Re: Mopar2DBone]
#1476714
07/31/13 12:45 AM
07/31/13 12:45 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
It works in the 80s beds..somebody posted pics of a cab in a bed just awhile back..
I am truckless..
[Re: 340SHORTY]
#1476715
07/31/13 09:41 AM
07/31/13 09:41 AM
Posts: 15,487 Florida
scratchnfotraction
how much body damage to the cab do you want? I hauled a cab on a small 8x10 trailer. 6 hrs of body work to fix the crease in the cab corners. add a hitch and tow a trailer behind a trailer. the wheel tubs are going to tilt the cab anyway you put it and the cab is going to get some dents by the time you man handle it on/off with a lift or not. NOW a truck bed is another story, I have fliped a long bed upside down on another long bed truck and used c-clamps to hold the bed rails together for a 150 mile ride at 55 mph. maybe some 4x4 or 2x6 across the bed rails and sit the cab on top of the bed rails and strap it off. good luck
[Re: scratchnfotraction]
#1476716
07/31/13 12:44 PM
07/31/13 12:44 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I have hauled a mid 80s cab in a mid 80s shortbed by stacking pallets 2 high front and rear of the bed for the rockers to sit on. It didnt have doors or glass, strapped thru windshield and rear window openings. It rode fine. I loaded it with a biig forklift, forks were long enough to go thru both front and rear pallets. Unloaded it with a hoist.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: E-Ticket]
#1476717
07/31/13 08:38 PM
07/31/13 08:38 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Has anyone ever transported a pick up truck cab shell in the bed of a pick up and if so, how well did it fit??
For the 1994 - 2002 era truck.....will a 1994 - 2002 cab shell fit in the bed of the this same era of truck?
The reason I ask is that we need to transport a cab and do not have enough trailer room left to set it on and I am wondering how far down (depth) in the bed will the truck cab fit in the bed??
Thanks!!!
Gonna be a great u-tube vid.....please let us know when it's up
A trailer with some dunnage to support the cab would be my choice
Rickster
[Re: Mopar2DBone]
#1476719
08/02/13 11:48 AM
08/02/13 11:48 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
The fellow I bout mine from said they (70's&80's) fit right in there. I wasn't sure, so I brought some wood to boost it. It sure looked like it would fit, but the wood was already there. Not sure of newer years,though. I wouldn't think they would be that much longer, front to rear. I guess you could just jack it up like I did. Traveled two hours at 60 mph with no trouble. The guy that loaded it thought it was funny enough to take a picture to show his brother. Both are members here. Maybe one of em will see this and chime in.
I have mechanical Aptitude. I can screw up anything.
[Re: jimbob101]
#1476723
08/02/13 01:29 PM
08/02/13 01:29 PM
bboogieart
Lost and Spaced
Right on jimbob got an 80's bed for me? Tell the truth, you get those pallets from N.E.W. plastics right? I used to work for them in the Coleman plant and the one I got from you looks exactly the same as the ones I had to build... Works like a dream. The 6X6s didn't hurt either. Just a little taller.
[Re: jimbob101]
#1476725
08/02/13 01:38 PM
08/02/13 01:38 PM
bboogieart
Lost and Spaced
Ha ha I thought the picture was your brothers place. There is an NEW plant right down the road from him. I worked at the other one. PM sent.
[Re: bboogieart]
#1476727
08/03/13 04:07 AM
08/03/13 04:07 AM
Posts: 2,525 Louisville, KY
E-Ticket
Louisville, KY
I wish this one would be that easy but one thing I forgot to mention is that the truck cab I am transporting is a "Quad Cab" so it wont be quite as easy as a standard cab. I may be taking a car hauler down there to pick this up and will still have room to load the car behind the cab........"barely".......
[Re: E-Ticket]
#1476730
08/03/13 03:10 PM
08/03/13 03:10 PM
bboogieart
Lost and Spaced
yep that changes everything, huh? AS for putting the cab on the trailer first. I would consider the weight of the car versus the cab. Should probably put the car on front and the cab in back.
