Good 8 inch converter and transbrake #1438918
05/19/13 04:36 PM
05/19/13 04:36 PM
Pismo Beach California
Green416 Offline OP
Green416  Offline OP
Looking for a trans brake and good 8 inch converter.Not trying to black list any certain brand,just was curious what has worked for you guys.Also without sounding to uninformed ,is the trans brake as easy as just changing the valve body?I know my trans had a brake on it before I bought it,but just has a reverse manual TA in it now.Just trying to research a little before I pull the trigger.Thanks in advance for any opinions.
1972 Duster W-5 416 10.22@133 1970 Cuda stuck in the 80's Pro Street
Re: Good 8 inch converter and transbrake [Re: Green416] #1438919
05/19/13 04:46 PM
05/19/13 04:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've had a T/A reverse VB brake for years... I've been
very happy with it BUT its not a low band apply... I
bought it well before they came out with the LBA...
and I like my 8" T/A conv.. its been in my car for
better than 10 years and its a 5600 stall and MOST time
I launch right up on the stall(no chip)
Re: Good 8 inch converter and transbrake [Re: Green416] #1438920
05/19/13 04:51 PM
05/19/13 04:51 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
continential converter here in socal is the best for 8in stuff that I know of...a great little shop been in the same place for more than 35 years
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Good 8 inch converter and transbrake [Re: WHITEDART] #1438921
05/19/13 05:20 PM
05/19/13 05:20 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I have a nice 8in forsale its a frank lupo.
Re: Good 8 inch converter and transbrake [Re: Green416] #1438922
05/19/13 05:30 PM
05/19/13 05:30 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
Grinner TB is the best hands down, He invented TB I believe, I have used both TCP and Conan I like my conan
Re: Good 8 inch converter and transbrake [Re: Green416] #1438923
05/19/13 06:07 PM
05/19/13 06:07 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Dave Smith @ Pro Trans has a nice clean neutral transbrake.
matt
[img] [/img]
Re: Good 8 inch converter and transbrake [Re: MR_P_BODY] #1438924
05/19/13 06:10 PM
05/19/13 06:10 PM
Green416 Offline OP
Green416  Offline OP
Is the Low Band Apply a good thing to have?i know it's a big no no to let off in first with my current valve body correct?Burnout in second into high,never starting in first because of the sprag.....?Does a LBA change this?
Re: Good 8 inch converter and transbrake [Re: clonestocker] #1438925
05/19/13 06:13 PM
05/19/13 06:13 PM
Green416 Offline OP
Green416  Offline OP
I believe the trans I have now is a ProTrans,but I don't have much info on how or what's in it.I bought it from Grape Ape a few years back and it was fresh but he couldn't remember exactly what was in it.He told me to call Dave and ask,but its been awhile and I'm sure he wouldn't remember,unless he keeps files.
Re: Good 8 inch converter and transbrake [Re: Scamp408] #1438926
05/19/13 06:14 PM
05/19/13 06:14 PM
Green416 Offline OP
Green416  Offline OP
P.M me with some info and price if you don't mind.Thanks
Re: Good 8 inch converter and transbrake [Re: Green416] #1438927
05/19/13 08:13 PM
05/19/13 08:13 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Grinder low band apply brake.... ATI convertor, are super solid choices
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Good 8 inch converter and transbrake [Re: Green416] #1438928
05/19/13 08:34 PM
05/19/13 08:34 PM
Dave stamps a seriel(SP?) number on his trans. on the bell housing lip directly above the starter Write it down and give him a call He usually paints the main case black and leaves the tailshaft unpainted on all of his trans. BTW, if you don't have billet drum now, get one Especially now with a trans brake I have used many 8 inch race converters, many. The best one I've had is a Turbo Action SS/AH 8 inch race converter used in a street and strip pump gas wedge No matter who you have make your converter make sure and tell them it is for a Trans. brake application
Re: Good 8 inch converter and transbrake [Re: Cab_Burge] #1438929
05/19/13 08:50 PM
05/19/13 08:50 PM
Green416 Offline OP
Green416  Offline OP
Thanks for all the info and yeah the trans is painted just as you described.I'll look for the number tomorrow.I know Grape Ape had a brake so hopefully it has a billet drum.I remember he sold the converter separate,and switched the brake for the manual valve body.Are they (brake) easy to install?
Re: Good 8 inch converter and transbrake [Re: Green416] #1438930
05/19/13 08:58 PM
05/19/13 08:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
By the way I put a T/A J conv in my Rampage with a
518 trans... test to start in a few weeks... its a
8" behind a 416 ci and Paul said it should stall at
5000 with 500 ft lbs of torque... I have 520 ft lbs
Re: Good 8 inch converter and transbrake [Re: Green416] #1438932
05/19/13 11:45 PM
05/19/13 11:45 PM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
8" A-1 and Griner, All the converter companys do a good job with their products. With Marv selling his interest In A-1, I would probably lean towards T/A, Those guys have been doing Mopar for a very long time. As far as the brake?! I like the Griner. It's fast, consistent and expensive but it has won me a LOT of races.
As far as availibility, here are a couple of numbers:
Keith @ www727 Specalists.com -219-718-3542 kfl727specialist@peoplepc.com
Lonnie @ wwwExtreme Automatics.com -513-898-0553 Lonnie@extremeautomatics.com
Re: Good 8 inch converter and transbrake [Re: ] #1438933
05/20/13 12:04 AM
05/20/13 12:04 AM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
TRANZACT OF INDY.
I will never use anything else.The best.They are sponsors on this site too! Right up at the top.
Goodluck trying to get a Griner.
FYI he stole his design from Griner.... I personally would not support a thief by purchasing his product...
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Good 8 inch converter and transbrake [Re: StripeHOG] #1438934
05/20/13 12:35 AM
05/20/13 12:35 AM
Portage,michigan
Portage,michigan
TRANZACT OF INDY.
I have heard this exact same thing from several people. And also that Joe at one time worked as an assistant for Griner.
The above is why I first bought a reverse manual valve body from Griner, and later a low band apply brake from Griner. The guy who did my trannies( Jim Paquette) who anybody in the Ford stock and super stock ranks is well aware of) recommended only the Griner Mopar brake when he built my trannies. That was plenty good enough endorsement for me.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Good 8 inch converter and transbrake [Re: B3422W5] #1438935
05/20/13 01:25 AM
05/20/13 01:25 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my junk runs a TA 8" converter with mech diode, very solid converter. has lasted years without needing any work done to it. i use the A&A Ultimate brake with LBA & safe neutral, very quick release brake, i'm sold on this combo. John Cope used to sell Grinners, but now he doesn't. not sure what that means.... but i've never heard of complaints with A&A, but i have with Grinner.
Re: Good 8 inch converter and transbrake [Re: rebel] #1438936
05/20/13 01:33 AM
05/20/13 01:33 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
ATI.....That is all
Re: Good 8 inch converter and transbrake [Re: 10secGTX] #1438937
05/20/13 02:00 AM
05/20/13 02:00 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Got 3 Tranzact of Indy brakes in use...all working great...
so if someone invented the wheel..did cragar...weld..centerline and everyone else steal it?..lol
was the wheel patented?
Tony
70 AARCuda Vitamin C
Re: Good 8 inch converter and transbrake [Re: Green416] #1438938
05/20/13 02:34 AM
05/20/13 02:34 AM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Tranzact LBA here. Works great! I use a T/A "J" converter .
