Re: New engine dyno numbers???? E street
[Re: demon440]
#1429712
05/05/13 09:18 PM
05/05/13 09:18 PM
Posts: 57 CT
440Kilmartin
CT
[Re: demon440]
#1429713
05/06/13 12:07 AM
05/06/13 12:07 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Isn't the combustion chamber in the head the same as the bowl?
Bowl is up stream from the valve .....towards the carb on intake , exh on exh. The typical choke point in a lot of heads and where big gains can come from when porting. Chamber = pocket on combustion face of cylinder head deck area where valves & spark plugs hide.
[Re: 440Kilmartin]
#1429716
05/06/13 12:18 PM
05/06/13 12:18 PM
Posts: 5,165 CT
GTX MATT
CT
Mike I probably didn't have a car with me since mine has been out of commission for about 2 years now (for about another month or so only, hopefully!) but I've got a gold '67 Satellite with a 440/4 speed.
Good luck with the 23 spline. I'm going to be pushing one soon too with my stock stroke 440, looking to be around 550 hp so I'll be a bit safer than you with the stock stroke and less torque, but still looking to put the hurt on it (and the 8 3/4 behind it). I've got 3 so I'm prepared to break one, trying to trade up for an 18 spline though.
You did have a 4.10 Dana though as I recall. You running a scatter sheild?
