New engine dyno numbers???? E street
#1429689
05/03/13 03:42 PM
05/03/13 03:42 PM
Posts: 57 CT
440Kilmartin
CT
Pump gas 500" hydraulic rb . EDELBROCK estreet heads. guess my dyno numbers
Re: New engine dyno numbers???? E street
[Re: 440Kilmartin]
#1429695
05/04/13 12:19 AM
05/04/13 12:19 AM
Posts: 57 CT
440Kilmartin
CT
Well it's a hughes 569/576 lift. heads have some port work .10.8:1 compression . She made 592hp @ 5500rpm and 648tq @ 4100 rpm . 4 speed full street car
[Re: 440Kilmartin]
#1429696
05/04/13 02:40 AM
05/04/13 02:40 AM
Posts: 43,257 Bend,OR USA
Cab_Burge
What size carb. did you do the dyno testing with? Did you do any timing and jetting testing?
[Re: Cab_Burge]
#1429697
05/04/13 03:42 AM
05/04/13 03:42 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Been considering building a similar engine. Curious what lifters,valve springs and rockers you used. Graph doesnt "look" like the power fell off after peak due to any lifter pump or float. Ive been considering a Howards .600 lift hydraulic roller.
Mopar to the bone!!!
[Re: Cab_Burge]
#1429698
05/04/13 07:44 AM
05/04/13 07:44 AM
Posts: 57 CT
440Kilmartin
CT
It's an old 850 holley . And yes we did spend the day playing with timing and jetting . It made the power with 35 degrees in it on pump gas... And can lifters and springs is all from Hughes .
