New engine dyno numbers???? E street #1429689
05/03/13 03:42 PM
05/03/13 03:42 PM
CT
440Kilmartin Offline OP
CT
Pump gas 500" hydraulic rb . EDELBROCK estreet heads. guess my dyno numbers
Re: New engine dyno numbers???? [Re: 440Kilmartin] #1429690
05/03/13 03:43 PM
05/03/13 03:43 PM
CT
CT
Pic
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429691
05/03/13 05:26 PM
05/03/13 05:26 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Without knowing much, I'll guess 540hp. And torque around 610.
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429692
05/03/13 06:15 PM
05/03/13 06:15 PM
600 HP and 640 Ft lbs on pump gas
Re: New engine dyno numbers???? E street [Re: Cab_Burge] #1429693
05/03/13 08:11 PM
05/03/13 08:11 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Not enough. It never is. I can only guess zero with the engine off since you didn't give no clues to nothing. A cadillac 500 pump gas hydraulic made around 290 hp. Get the point?
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429694
05/03/13 08:26 PM
05/03/13 08:26 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Cam size?
Compression Ratio?
Head Work?
Carb size?
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429695
05/04/13 12:19 AM
05/04/13 12:19 AM
CT
CT
Well it's a hughes 569/576 lift. heads have some port work .10.8:1 compression . She made 592hp @ 5500rpm and 648tq @ 4100 rpm . 4 speed full street car
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429696
05/04/13 02:40 AM
05/04/13 02:40 AM
What size carb. did you do the dyno testing with? Did you do any timing and jetting testing?
Re: New engine dyno numbers???? E street [Re: Cab_Burge] #1429697
05/04/13 03:42 AM
05/04/13 03:42 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Been considering building a similar engine. Curious what lifters,valve springs and rockers you used. Graph doesnt "look" like the power fell off after peak due to any lifter pump or float. Ive been considering a Howards .600 lift hydraulic roller.
Mopar to the bone!!!
Re: New engine dyno numbers???? E street [Re: Cab_Burge] #1429698
05/04/13 07:44 AM
05/04/13 07:44 AM
CT
CT
It's an old 850 holley . And yes we did spend the day playing with timing and jetting . It made the power with 35 degrees in it on pump gas...
And can lifters and springs is all from Hughes .
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429699
05/04/13 09:21 AM
05/04/13 09:21 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Those are nice numbers. That should put your mph solidly into the mid 120s and et in the 10s.
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429700
05/04/13 10:18 AM
05/04/13 10:18 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I hope you have some good drive line parts . Good numbers .
Re: New engine dyno numbers???? E street [Re: justinp61] #1429701
05/04/13 11:03 AM
05/04/13 11:03 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
Nice numbers!
On another note, I don't really get the deal with the E Streets. They same to have the same specs as the RPMs and cost the same. Some of the hardware they put on them is different right? I don't get why they have two different offerings that are so similar.
Re: New engine dyno numbers???? E street [Re: 67Satty] #1429702
05/04/13 11:54 AM
05/04/13 11:54 AM
CT
CT
They are identical except for the springs which were changed anyways EDELBROCK says that the rpm and estreets are made from the same castings and just wanted to offer a small chamber head to improve low compression street motors. I got mine when they first came out on sale for quite a bit less than the rpm
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429703
05/04/13 12:03 PM
05/04/13 12:03 PM
What CC are those heads?
Re: New engine dyno numbers???? E street [Re: Cab_Burge] #1429704
05/04/13 12:15 PM
05/04/13 12:15 PM
CT
CT
84cc with port work and some bowl work
Re: New engine dyno numbers???? E street [Re: 440Kilmartin] #1429705
05/04/13 12:45 PM
05/04/13 12:45 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I thought that they came with 75cc chambers? If so, then 84cc now would mean a lot of bowl work.
Re: New engine dyno numbers???? E street [Re: BSB67] #1429706
05/04/13 12:50 PM
05/04/13 12:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What does bowl work have 2 do w/chamber cc`s?
Re: New engine dyno numbers???? E street [Re: Thumperdart] #1429707
05/04/13 12:54 PM
05/04/13 12:54 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Nothing....mis-spoke.
Still, I thought they had 75 cc chambers.
Re: New engine dyno numbers???? E street [Re: BSB67] #1429708
05/04/13 12:57 PM
05/04/13 12:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I understand............
