Re: dragster
[Re: jamesc]
#1424233
04/23/13 10:15 PM
04/23/13 10:15 PM
Posts: 142 illinois
evenflow
illinois
jw bell, ati midplate kit/adapter for mopar to chevy bell housing (chevy pattern is easier to find/borrow in a pinch if yours goes down) hughes soft hit convertor starter upside down on right side
Re: dragster
[Re: Bob_Spelic]
#1424238
04/24/13 01:06 PM
04/24/13 01:06 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Your midplate has to allow the starter to bolt to the Ultra-Bell, otherwise you'll be nowhere close to the flexplate. You will have to shim it then so that you are not to deep into the flexplate.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
Re: dragster
[Re: Slingshot383]
#1424239
04/24/13 05:56 PM
04/24/13 05:56 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I would mount the starter to the mid plate,that's the way I done mine.Almost forgot I use the mid plate as the adapter,that way the standard glide bolts to it with no mods.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
Re: dragster
[Re: Cab_Burge]
#1424242
04/25/13 10:05 AM
04/25/13 10:05 AM
MRMOPAR622
Sweet Home Alabama
Engine kick back is what breaks the starters and fly-wheels(ring gear on the converter TF).But I have found the ultimate remedy for that a 16 Volt battery.I used to break a couple of starter snouts & at least one flywheel with the glide ring gear on the converter with TF for years.I went to 16 Volt batteries 5 years ago and have not broke one since.I still sometimes have a spit back through the injector on my dragster's and carbs on the door cars,but no kick back.The 16 volt batteries are stronger and turn the engine faster and eliminate all kick back. I know this has nothing to do with helping the man get his engine in his dragster,but since it was brought up was hoping this could help him as well as others.I know I owe a lot of THANKS to the people on this site for all the help they have given me in the past.
