dragster #1424228
04/23/13 12:35 PM
04/23/13 12:35 PM
Florida, USA
MoparMichael Offline OP
Florida, USA
putting big block mopar in dragster going to use glide. have j w bell housing it uses mopar starter. what cov. would I use mopar with glide snout or chevy with fly wheel ? thanks
Re: dragster [Re: MoparMichael] #1424229
04/23/13 03:14 PM
04/23/13 03:14 PM
Which flexplate did you buy? If none yet buy the parts, all of them, you need to use the Mopar starter on the flexplate for the Mopar crankshaft. I am going through this now on a tube chassis car with a glide in it using a JW flexplate for a JW bellhousing, it is a Mikes Monster Glide built in a Ried SFI Chevy glide case, I'm having starter engagement issues now Call Mikes 661-723-0081 for the correct parts
Re: dragster [Re: Cab_Burge] #1424230
04/23/13 07:56 PM
04/23/13 07:56 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I use the JW wheel flexplate and a GM converter.
Mopar Block
Mopar Starter
Re: dragster [Re: Cab_Burge] #1424231
04/23/13 08:41 PM
04/23/13 08:41 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Cab, I think starter engagement issues are common for that combination and that's why JW includes 3 or 4 spacers for the starter. I currently use 2 spacers on my smallblock and use one of the Mopsr mini starters that is at least 25 yrs old.
Re: dragster [Re: MoparMichael] #1424232
04/23/13 09:24 PM
04/23/13 09:24 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
j&w bell, ATI flywheel, adapter and converter
Re: dragster [Re: jamesc] #1424233
04/23/13 10:15 PM
04/23/13 10:15 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
jw bell, ati midplate kit/adapter for mopar to chevy bell housing (chevy pattern is easier to find/borrow in a pinch if yours goes down) hughes soft hit convertor starter upside down on right side
Re: dragster [Re: evenflow] #1424234
04/23/13 10:35 PM
04/23/13 10:35 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
I would guess the convertor would depend on what input shaft is on the glide. I was up at JW's today to have an ultra bell installed and going to a 1.76 from a 1.82 and have to change the convertor snout because of the change.Call them they will help you 321-632-6205
Re: dragster [Re: Blucuda413] #1424235
04/24/13 01:00 AM
04/24/13 01:00 AM
This one spins without touching the ring gear I will jack it up on jack stands and get under it to see if I can fix easy or see if I can figure out what is wrong. It does have a thick mid plate and the starter was lossely bolted onto it when I pick the car up, I had to change the flexplate and add a spacer to get the converter end play right so who knows what is wrong now I can FIX IT, I have a wonderful set of tools I'm hoping and praying that it is a easy fix
Re: dragster [Re: Biginchmopar] #1424236
04/24/13 11:57 AM
04/24/13 11:57 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Mopar Block
Mopar Starter
Don't forget you need a spacer that fits on the back side of the JW wheel to hold the GM converter snout.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: dragster [Re: MoparMichael] #1424237
04/24/13 12:40 PM
04/24/13 12:40 PM
Cheswick, PA
Bob_Spelic Offline
Bob_Spelic  Offline
Cheswick, PA
Stock case Power glide with bell cut off
JW ultra bell
JW wheel (flexplate)
JW starter shim kit (most dratser use 1/4 to 3/8 mid plates)
JW Flexplate shim kit (same as above, but adapts the nose of the converter)
GM converter for power glide (you can go turbo shaft or power glide shaft ......your choice)
Bob Spelic
Re: dragster [Re: Bob_Spelic] #1424238
04/24/13 01:06 PM
04/24/13 01:06 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Your midplate has to allow the starter to bolt to the Ultra-Bell, otherwise you'll be nowhere close to the flexplate. You will have to shim it then so that you are not to deep into the flexplate.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: dragster [Re: Slingshot383] #1424239
04/24/13 05:56 PM
04/24/13 05:56 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I would mount the starter to the mid plate,that's the way I done mine.Almost forgot I use the mid plate as the adapter,that way the standard glide bolts to it with no mods.
Re: dragster [Re: MRMOPAR622] #1424240
04/24/13 06:14 PM
04/24/13 06:14 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Something to consider, the Ultrabell has a register for the starter snout.
If you bolt the starter to the mid-plate the starter snout may not be supported and it will break at the worst time.
Re: dragster [Re: AAR-B4] #1424241
04/25/13 03:09 AM
04/25/13 03:09 AM
My starter gear is missing engaging the teeth on the flexplate by about.100 by eyeballing it. The starter is a Powermaster #9513 for Mopars, it is mounted on the .275 thick midplate along with a .630 thick spacer mounted onto front of the midplate. I removed the spacer tonight and I"ll mount the starter onto the bolts tomorrow morning and see how much the starter teeth will engage the ring gear teeth I may end up having the spacer milled down to get it so the starter gear is around .080 at rest from the ring gear teeth
Re: dragster [Re: Cab_Burge] #1424242
04/25/13 10:05 AM
04/25/13 10:05 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Engine kick back is what breaks the starters and fly-wheels(ring gear on the converter TF).But I have found the ultimate remedy for that a 16 Volt battery.I used to break a couple of starter snouts & at least one flywheel with the glide ring gear on the converter with TF for years.I went to 16 Volt batteries 5 years ago and have not broke one since.I still sometimes have a spit back through the injector on my dragster's and carbs on the door cars,but no kick back.The 16 volt batteries are stronger and turn the engine faster and eliminate all kick back.
I know this has nothing to do with helping the man get his engine in his dragster,but since it was brought up was hoping this could help him as well as others.I know I owe a lot of THANKS to the people on this site for all the help they have given me in the past.
