Page 2 of 4 1 2 3 4
Re: How many here actually..... [Re: dartman366] #1420794
04/16/13 04:57 PM
04/16/13 04:57 PM
Locomotion Offline
Locomotion  Offline
I swap rear slicks & check/adjust the rear brakes after every racing weekend, but I don't use a torque wrench. I don't think I over-torque them, but after years of tightening & loosening them by hand, I broke my 4-way!
(Cheap China junk that apparently everybody sells.)
So now I carry a spare.
Re: How many here actually..... [Re: poboyengineering] #1420795
04/16/13 04:59 PM
04/16/13 04:59 PM
Az
Crizila Offline
Crizila  Offline
Az
every car, every wheel, every time.
it's my security blanket.
Fastest 300
Re: How many here actually..... [Re: Crizila] #1420796
04/16/13 05:20 PM
04/16/13 05:20 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i torque everything.
Re: How many here actually..... [Re: Crizila] #1420797
04/16/13 05:24 PM
04/16/13 05:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Heck yeah; I've done it so many times that I can feel 75 ft/lbs, but I check it anyway.
On "mag"-wheel cars & my trailer, I check 'em periodically; though I've never had a loose-wheel problem, I like to keep it that way.
Re: How many here actually..... [Re: topside] #1420798
04/16/13 05:31 PM
04/16/13 05:31 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
I still use old school Cragar Super Tricks from the early seventies. Cragar was big on torquing those to 55 lbs...so I got into the habit and never stopped.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: How many here actually..... [Re: Steve1118] #1420799
04/16/13 05:56 PM
04/16/13 05:56 PM
Q
Quicktree Offline
Quicktree  Offline
Q
absolutely
Re: How many here actually..... [Re: Quicktree] #1420800
04/16/13 06:48 PM
04/16/13 06:48 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Never used to on factory steel wheels that have that raised shoulder that will provide a bit of compression applied back to the lugnut. Never had a problem but I was probably applying at least 85ft/lbs or more. Factory Mopar wheels don't have that shoulder, so those would get torqued. In the last few years, I now break out the torque wrench on everything just to be sure.
Have always retorqued any mag-style wheel. They are notorious for loosening.
Lately, I torqued my factory aluminum wheels to the specified 100 ft/lbs and the stud broke free in the hub!! I guess I shouldn't have shot that WD-40 on it. Next time, after I fix it, I'll lower the spec to 85 ft/lbs.
Re: How many here actually..... [Re: Dean_Kuzluzski] #1420801
04/16/13 06:57 PM
04/16/13 06:57 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
I torque
Re: How many here actually..... [Re: scatpacktom] #1420802
04/16/13 07:09 PM
04/16/13 07:09 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
105ft/lbs on my 1/2" studs on the Dart. I do 140 ft/lbs on the 9/16" studs on my trucks. I do this to eliminate the need to re-check them.
Mopar to the bone!!!
Re: How many here actually..... [Re: dartman366] #1420803
04/16/13 07:12 PM
04/16/13 07:12 PM
Indiana
MFR426 Offline
MFR426  Offline
Indiana
We torque every vehicle we have including the garden tractor!
Re: How many here actually..... [Re: scatpacktom] #1420804
04/16/13 07:12 PM
04/16/13 07:12 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I started torquing then about 15 years ago when I was working as a repairman at Chrysler's Ram assembly plant.
It was required after removing any wheel for a repair. They wanted the torque verified and recorded.
Now I do it every time I take r&r a wheel on every vehicle.
I've seen too many weak impacts over the years.
Re: How many here actually..... [Re: SNK-EYZ] #1420805
04/16/13 07:21 PM
04/16/13 07:21 PM
in a chair
mopartony Offline
mopartony  Offline
in a chair
Everytime I take the car to the track. When I crewed the fast cars, sub 7 seconds, every pass. Especially after shake....
Re: How many here actually..... [Re: mopartony] #1420806
04/16/13 07:25 PM
04/16/13 07:25 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Yes and on everything I can . without the wrench I break stuff.
Re: How many here actually..... [Re: Scamp408] #1420807
04/16/13 07:36 PM
04/16/13 07:36 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I torque everything before and after each race!The day after the race I clean everything up from front-back,bottom-top and torque everything.I have a pre race check list,to make sure everything gets checked!I torque my rear wheels at 100 lbs also.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: How many here actually..... [Re: Scamp408] #1420808
04/16/13 07:41 PM
04/16/13 07:41 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I torque when installing or changing on all vehicles, and on the race car I re-check every 2-3 rounds, front and rear. With the Weld ProStars I follow their recommendation of 85 lbs/ft on the front 1/2" studs, and 135 lbs/ft on the rear 5/8" studs.
Re: How many here actually..... [Re: ProStDodge] #1420809
04/16/13 08:09 PM
04/16/13 08:09 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
who uses a little antisieze or oil on the lugs?
Re: How many here actually..... [Re: Cheatham] #1420810
04/16/13 08:17 PM
04/16/13 08:17 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I use anti-seize on mine and have a finely calibrated 4-way lug wrench.... but double check them fairly often in true OCD fashion.
Re: How many here actually..... [Re: Cheatham] #1420811
04/16/13 08:32 PM
04/16/13 08:32 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
who uses a little antiseize or oil on the lugs?
Once a year, I hit the lugs with a little penetrating oil...
Re: How many here actually..... [Re: dartman366] #1420812
04/16/13 08:42 PM
04/16/13 08:42 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
What are you talking about.. You KNOW we are all perfect on here,,,NO body on HERE would race without torquing their nuts..
If you like drag racing, support your local track.
Re: How many here actually..... [Re: CHAPPER] #1420813
04/16/13 08:55 PM
04/16/13 08:55 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Never have but do check them for tightness from time to time ........ if I remember to what was the question
Russ
Page 2 of 4 1 2 3 4
