Re: How many here actually.....
[Re: dartman366]
#1420794
04/16/13 04:57 PM
04/16/13 04:57 PM
Posts: 5,895 Florida
Locomotion
I swap rear slicks & check/adjust the rear brakes after every racing weekend, but I don't use a torque wrench. I don't think I over-torque them, but after years of tightening & loosening them by hand, I broke my 4-way! (Cheap China junk that apparently everybody sells.) So now I carry a spare.
[Re: topside]
#1420798
04/16/13 05:31 PM
04/16/13 05:31 PM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
I still use old school Cragar Super Tricks from the early seventies. Cragar was big on torquing those to 55 lbs...so I got into the habit and never stopped.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
[Re: Steve1118]
#1420799
04/16/13 05:56 PM
04/16/13 05:56 PM
Quicktree
[Re: Quicktree]
#1420800
04/16/13 06:48 PM
04/16/13 06:48 PM
Posts: 8,943 Holly/MI
Dean_Kuzluzski
Holly/MI
Never used to on factory steel wheels that have that raised shoulder that will provide a bit of compression applied back to the lugnut. Never had a problem but I was probably applying at least 85ft/lbs or more. Factory Mopar wheels don't have that shoulder, so those would get torqued. In the last few years, I now break out the torque wrench on everything just to be sure. Have always retorqued any mag-style wheel. They are notorious for loosening. Lately, I torqued my factory aluminum wheels to the specified 100 ft/lbs and the stud broke free in the hub!! I guess I shouldn't have shot that WD-40 on it. Next time, after I fix it, I'll lower the spec to 85 ft/lbs.
[Re: scatpacktom]
#1420802
04/16/13 07:09 PM
04/16/13 07:09 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
105ft/lbs on my 1/2" studs on the Dart. I do 140 ft/lbs on the 9/16" studs on my trucks. I do this to eliminate the need to re-check them.
Mopar to the bone!!!
[Re: scatpacktom]
#1420804
04/16/13 07:12 PM
04/16/13 07:12 PM
Posts: 10,164 A Red State
SNK-EYZ
A Red State
I started torquing then about 15 years ago when I was working as a repairman at Chrysler's Ram assembly plant.
It was required after removing any wheel for a repair. They wanted the torque verified and recorded.
Now I do it every time I take r&r a wheel on every vehicle.
I've seen too many weak impacts over the years.
[Re: Scamp408]
#1420807
04/16/13 07:36 PM
04/16/13 07:36 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
I torque everything before and after each race!The day after the race I clean everything up from front-back,bottom-top and torque everything.I have a pre race check list,to make sure everything gets checked!I torque my rear wheels at 100 lbs also.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Cheatham]
#1420811
04/16/13 08:32 PM
04/16/13 08:32 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
who uses a little antiseize or oil on the lugs?
Once a year, I hit the lugs with a little penetrating oil...
