Now my Optima pooped out.. #1414804
04/05/13 09:32 AM
04/05/13 09:32 AM
tboomer Online work OP
tboomer  Online Work OP
My red top Optima finally died. Can't really complain,it has been in my car since 2005 and has been recharged 100s of times. I don't plan on another Optima,I hear the quality just isn't there. For a car that hits the track only a few times a year,what would you fellas buy? Thanks!! Ted
Re: Now my Optima pooped out.. [Re: tboomer] #1414805
04/05/13 09:41 AM
04/05/13 09:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've used the same old Die Hard from Sams Club... its
been in there 9 years... never been charged with a
charger.. just the alt... just the single battery in
my car
EDIT
I put the same one in my Rampage so I'll see how long
that one last
Re: Now my Optima pooped out.. [Re: MR_P_BODY] #1414806
04/05/13 09:44 AM
04/05/13 09:44 AM
Thanks,Mike! For the first 3 years,I ran without an alternator...so this thing took a beating! In my street stuff,I have had good luck with Interstate..
Re: Now my Optima pooped out.. [Re: tboomer] #1414807
04/05/13 10:51 AM
04/05/13 10:51 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Ever consider the auto salvage yards? Nearly new batteries for $30-$35.
Master, again and still
Re: Now my Optima pooped out.. [Re: DaveRS23] #1414808
04/05/13 10:56 AM
04/05/13 10:56 AM
I must admit that I am cheap..I will look!
Re: Now my Optima pooped out.. [Re: tboomer] #1414809
04/05/13 11:26 AM
04/05/13 11:26 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I have had good luck with Die Hard and Interstate for years.
Re: Now my Optima pooped out.. [Re: dartman366] #1414810
04/05/13 12:05 PM
04/05/13 12:05 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
I gave up on Optima after three of them went to crap in a little over a year.
I too have had good luck with Interstate
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Now my Optima pooped out.. [Re: megajoltman] #1414811
04/05/13 12:55 PM
04/05/13 12:55 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
My marine Sears die hard lived in my race-car for 7 years no alternator recharge after every round then lasted another 3 years in my trailer.But I tore up 3-4 starters every year & at least one flywheel per year using it,from kick back when starting the engine.Went to a 16 Volt have not had any engine kick back nor broke any starters.My Rock battery died this year after 3 years of service.After do as much research as I could it come down to either the 16 volt Rock or XS battery.I picked the Rock again because it has 1,050 CCA VS XS 675 CCA,The tech. @ Rock said it needed 12-15 mins between rounds to fully recharge,the tech. @ XS said their battery needed 25-30 mins. between rounds to fully recharge.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Now my Optima pooped out.. [Re: megajoltman] #1414812
04/05/13 03:03 PM
04/05/13 03:03 PM
Ohio
V
viperakron Offline
viperakron  Offline
V
Ohio
Optima is made in Mexico or China now. Not the same quality they started with.
Re: Now my Optima pooped out.. [Re: viperakron] #1414813
04/05/13 05:58 PM
04/05/13 05:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I get my batteries from my local CAT store.
Mopar to the bone!!!
Re: Now my Optima pooped out.. [Re: 72Swinger] #1414814
04/05/13 06:03 PM
04/05/13 06:03 PM
Guitar Jones Offline
I have 2 Mopar batteries in my car...
Might need that second one after the other one fails.
But they've been there for 5 years now. I run a 90 amp alternator and use a battery tender when it sits. I never need to charge them at the track.
Re: Now my Optima pooped out.. [Re: viperakron] #1414815
04/05/13 06:30 PM
04/05/13 06:30 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Mexico...
Just my $0.02..
Re: Now my Optima pooped out.. [Re: Sinitro] #1414816
04/05/13 07:11 PM
04/05/13 07:11 PM
Lehigh Acres, Florida
rickstershemi Offline
If you don't run an alternator....I strongly suggest a drycell such as Odyssey
Rickster
Re: Now my Optima pooped out.. [Re: rickstershemi] #1414817
04/06/13 02:48 AM
04/06/13 02:48 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Rickster
Yes, the odyssey batteries are very good batteries...
The sears Die hard "Platinum" battery is the same exact thing as an Odyssey battery, only a 100 bucks cheaper....made in the same exact plant, same materials, same AGM technology, just with the sears platinum badging...
I have one in my mopar, and that is the best battery iv'e ever owned.
http://www.sears.com/diehard-platinum-automotive-battery-group-size-34-price/p-02850034000P
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Now my Optima pooped out.. [Re: mopardude318] #1414818
04/06/13 11:00 AM
04/06/13 11:00 AM
Rickster
That is a great price....but I prefer the Odyssey PC1200MJT it's only 38lbs compared to 53lbs and the the posts are a better setup in my opinion $266.00
Rickster
Re: Now my Optima pooped out.. [Re: rickstershemi] #1414819
04/14/13 07:47 AM
04/14/13 07:47 AM
Just a little update..I went to Hudson,Iowa yesterday to talk to Radar at R&J about my Victor heads. Stopped at Blaines Farm and Fleet and bought a big Diehard Gold battery with 880 CCAs...96.00 plus a 7.00 core charge. Good price for a 100 month battery with a free 3 year replacement! That should keep the MSD happy!!
Re: Now my Optima pooped out.. [Re: viperakron] #1414820
04/14/13 10:41 AM
04/14/13 10:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Really? I was going to replace mine that's been sitting dormant for the last 3 years (and assumed to have gone bad) w/ another one because I actually had good results with it. If they're not as good now as the original one I bought 5 years ago, that's too bad.
FWIW, my family's daily drivers all have either Interstate or Die Hards in them and the Interstates have generally lasted right about 5 years before needing replacement.
Re: Now my Optima pooped out.. [Re: BradH] #1414821
04/14/13 10:44 AM
04/14/13 10:44 AM
Brad...They tried to sell me another Optima. I told him no thanks...I think the one he tried to sell me was like my old one...160.00!!
Re: Now my Optima pooped out.. [Re: tboomer] #1414822
04/14/13 10:55 AM
04/14/13 10:55 AM
BradH Offline
BradH  Offline
Yeah, I think the one I bought around 2007-2008 was close to $150, so that's not surprising.
Re: Now my Optima pooped out.. [Re: BradH] #1414823
04/14/13 11:04 AM
04/14/13 11:04 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I have 3 of the newer optima's and although I am not happy with them shipping the labor out I have no problems with any of them. if you run a red top you need an alternator.
and I just payed $153 for mine form summit with free delivery
