Now my Optima pooped out.. #1414804
04/05/13 09:32 AM
04/05/13 09:32 AM
tboomer Offline OP
tboomer  Offline OP
My red top Optima finally died. Can't really complain,it has been in my car since 2005 and has been recharged 100s of times. I don't plan on another Optima,I hear the quality just isn't there. For a car that hits the track only a few times a year,what would you fellas buy? Thanks!! Ted
Re: Now my Optima pooped out.. [Re: tboomer] #1414805
04/05/13 09:41 AM
04/05/13 09:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've used the same old Die Hard from Sams Club... its
been in there 9 years... never been charged with a
charger.. just the alt... just the single battery in
my car
EDIT
I put the same one in my Rampage so I'll see how long
that one last
Re: Now my Optima pooped out.. [Re: MR_P_BODY] #1414806
04/05/13 09:44 AM
04/05/13 09:44 AM
tboomer Offline OP
tboomer  Offline OP
Thanks,Mike! For the first 3 years,I ran without an alternator...so this thing took a beating! In my street stuff,I have had good luck with Interstate..
Re: Now my Optima pooped out.. [Re: tboomer] #1414807
04/05/13 10:51 AM
04/05/13 10:51 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Ever consider the auto salvage yards? Nearly new batteries for $30-$35.
Master, again and still
Re: Now my Optima pooped out.. [Re: DaveRS23] #1414808
04/05/13 10:56 AM
04/05/13 10:56 AM
tboomer Offline OP
tboomer  Offline OP
I must admit that I am cheap..I will look!
Re: Now my Optima pooped out.. [Re: tboomer] #1414809
04/05/13 11:26 AM
04/05/13 11:26 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I have had good luck with Die Hard and Interstate for years.
Re: Now my Optima pooped out.. [Re: dartman366] #1414810
04/05/13 12:05 PM
04/05/13 12:05 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
I gave up on Optima after three of them went to crap in a little over a year.
I too have had good luck with Interstate
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Now my Optima pooped out.. [Re: megajoltman] #1414811
04/05/13 12:55 PM
04/05/13 12:55 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
My marine Sears die hard lived in my race-car for 7 years no alternator recharge after every round then lasted another 3 years in my trailer.But I tore up 3-4 starters every year & at least one flywheel per year using it,from kick back when starting the engine.Went to a 16 Volt have not had any engine kick back nor broke any starters.My Rock battery died this year after 3 years of service.After do as much research as I could it come down to either the 16 volt Rock or XS battery.I picked the Rock again because it has 1,050 CCA VS XS 675 CCA,The tech. @ Rock said it needed 12-15 mins between rounds to fully recharge,the tech. @ XS said their battery needed 25-30 mins. between rounds to fully recharge.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Now my Optima pooped out.. [Re: megajoltman] #1414812
04/05/13 03:03 PM
04/05/13 03:03 PM
Ohio
V
viperakron Offline
viperakron  Offline
V
Ohio
Optima is made in Mexico or China now. Not the same quality they started with.
Re: Now my Optima pooped out.. [Re: viperakron] #1414813
04/05/13 05:58 PM
04/05/13 05:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I get my batteries from my local CAT store.
Mopar to the bone!!!
Re: Now my Optima pooped out.. [Re: 72Swinger] #1414814
04/05/13 06:03 PM
04/05/13 06:03 PM
Guitar Jones Offline
I have 2 Mopar batteries in my car...
Might need that second one after the other one fails.
But they've been there for 5 years now. I run a 90 amp alternator and use a battery tender when it sits. I never need to charge them at the track.
Re: Now my Optima pooped out.. [Re: viperakron] #1414815
04/05/13 06:30 PM
04/05/13 06:30 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Mexico...
Just my $0.02..
Re: Now my Optima pooped out.. [Re: Sinitro] #1414816
04/05/13 07:11 PM
04/05/13 07:11 PM
Lehigh Acres, Florida
rickstershemi Offline
If you don't run an alternator....I strongly suggest a drycell such as Odyssey
Rickster
Re: Now my Optima pooped out.. [Re: rickstershemi] #1414817
04/06/13 02:48 AM
04/06/13 02:48 AM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
Rickster
Yes, the odyssey batteries are very good batteries...
The sears Die hard "Platinum" battery is the same exact thing as an Odyssey battery, only a 100 bucks cheaper....made in the same exact plant, same materials, same AGM technology, just with the sears platinum badging...
I have one in my mopar, and that is the best battery iv'e ever owned.
http://www.sears.com/diehard-platinum-automotive-battery-group-size-34-price/p-02850034000P
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: Now my Optima pooped out.. [Re: mopardude318] #1414818
04/06/13 11:00 AM
04/06/13 11:00 AM
Rickster
That is a great price....but I prefer the Odyssey PC1200MJT it's only 38lbs compared to 53lbs and the the posts are a better setup in my opinion $266.00
Rickster
Re: Now my Optima pooped out.. [Re: rickstershemi] #1414819
04/14/13 07:47 AM
04/14/13 07:47 AM
tboomer Offline OP
tboomer  Offline OP
Just a little update..I went to Hudson,Iowa yesterday to talk to Radar at R&J about my Victor heads. Stopped at Blaines Farm and Fleet and bought a big Diehard Gold battery with 880 CCAs...96.00 plus a 7.00 core charge. Good price for a 100 month battery with a free 3 year replacement! That should keep the MSD happy!!
Re: Now my Optima pooped out.. [Re: viperakron] #1414820
04/14/13 10:41 AM
04/14/13 10:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Really? I was going to replace mine that's been sitting dormant for the last 3 years (and assumed to have gone bad) w/ another one because I actually had good results with it. If they're not as good now as the original one I bought 5 years ago, that's too bad.
FWIW, my family's daily drivers all have either Interstate or Die Hards in them and the Interstates have generally lasted right about 5 years before needing replacement.
Re: Now my Optima pooped out.. [Re: BradH] #1414821
04/14/13 10:44 AM
04/14/13 10:44 AM
tboomer Offline OP
tboomer  Offline OP
Brad...They tried to sell me another Optima. I told him no thanks...I think the one he tried to sell me was like my old one...160.00!!
Re: Now my Optima pooped out.. [Re: tboomer] #1414822
04/14/13 10:55 AM
04/14/13 10:55 AM
BradH Offline
BradH  Offline
Yeah, I think the one I bought around 2007-2008 was close to $150, so that's not surprising.
Re: Now my Optima pooped out.. [Re: BradH] #1414823
04/14/13 11:04 AM
04/14/13 11:04 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I have 3 of the newer optima's and although I am not happy with them shipping the labor out I have no problems with any of them. if you run a red top you need an alternator.
and I just payed $153 for mine form summit with free delivery
