Re: Now my Optima pooped out..
[Re: tboomer]
#1414807
04/05/13 10:51 AM
04/05/13 10:51 AM
Posts: 12,174 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Ever consider the auto salvage yards? Nearly new batteries for $30-$35.
Master, again and still
[Re: tboomer]
#1414809
04/05/13 11:26 AM
04/05/13 11:26 AM
dartman366
Mt. Vernon, Ohio
I have had good luck with Die Hard and Interstate for years.
[Re: dartman366]
#1414810
04/05/13 12:05 PM
04/05/13 12:05 PM
Posts: 4,085 The Wet Coast, Canada
megajoltman
I gave up on Optima after three of them went to crap in a little over a year.
I too have had good luck with Interstate
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: megajoltman]
#1414811
04/05/13 12:55 PM
04/05/13 12:55 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
My marine Sears die hard lived in my race-car for 7 years no alternator recharge after every round then lasted another 3 years in my trailer.But I tore up 3-4 starters every year & at least one flywheel per year using it,from kick back when starting the engine.Went to a 16 Volt have not had any engine kick back nor broke any starters.My Rock battery died this year after 3 years of service.After do as much research as I could it come down to either the 16 volt Rock or XS battery.I picked the Rock again because it has 1,050 CCA VS XS 675 CCA,The tech. @ Rock said it needed 12-15 mins between rounds to fully recharge,the tech. @ XS said their battery needed 25-30 mins. between rounds to fully recharge.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: viperakron]
#1414813
04/05/13 05:58 PM
04/05/13 05:58 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I get my batteries from my local CAT store.
Mopar to the bone!!!
[Re: 72Swinger]
#1414814
04/05/13 06:03 PM
04/05/13 06:03 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I have 2 Mopar batteries in my car... Might need that second one after the other one fails. But they've been there for 5 years now. I run a 90 amp alternator and use a battery tender when it sits. I never need to charge them at the track.
[Re: viperakron]
#1414815
04/05/13 06:30 PM
04/05/13 06:30 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Optima is made in Mexico or China now. Not the same quality they started with.
Mexico...
Just my $0.02..
[Re: mopardude318]
#1414818
04/06/13 11:00 AM
04/06/13 11:00 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
If you don't run an alternator....I strongly suggest a drycell such as Odyssey
Rickster
Yes, the odyssey batteries are very good batteries...
The sears Die hard "Platinum" battery is the same exact thing as an Odyssey battery, only a 100 bucks cheaper....made in the same exact plant, same materials, same AGM technology, just with the sears platinum badging...
I have one in my mopar, and that is the best battery iv'e ever owned.
http://www.sears.com/diehard-platinum-automotive-battery-group-size-34-price/p-02850034000P
That is a great price....but I prefer the Odyssey PC1200MJT it's only 38lbs compared to 53lbs and the the posts are a better setup in my opinion $266.00
Rickster
[Re: viperakron]
#1414820
04/14/13 10:41 AM
04/14/13 10:41 AM
BradH
Really? I was going to replace mine that's been sitting dormant for the last 3 years (and assumed to have gone bad) w/ another one because I actually had good results with it. If they're not as good now as the original one I bought 5 years ago, that's too bad.
FWIW, my family's daily drivers all have either Interstate or Die Hards in them and the Interstates have generally lasted right about 5 years before needing replacement.
[Re: tboomer]
#1414822
04/14/13 10:55 AM
04/14/13 10:55 AM
BradH
Brad...They tried to sell me another Optima. I told him no thanks...I think the one he tried to sell me was like my old one...160.00!!
Yeah, I think the one I bought around 2007-2008 was close to $150, so that's not surprising.
