Re: Now my Optima pooped out..
[Re: tboomer]
#1414807
04/05/13 10:51 AM
04/05/13 10:51 AM
Posts: 12,076 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Ever consider the auto salvage yards? Nearly new batteries for $30-$35.
Master, again and still
[Re: tboomer]
#1414809
04/05/13 11:26 AM
04/05/13 11:26 AM
dartman366
Mt. Vernon, Ohio
I have had good luck with Die Hard and Interstate for years.
[Re: dartman366]
#1414810
04/05/13 12:05 PM
04/05/13 12:05 PM
Posts: 4,085 The Wet Coast, Canada
megajoltman
I gave up on Optima after three of them went to crap in a little over a year.
I too have had good luck with Interstate
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
[Re: megajoltman]
#1414811
04/05/13 12:55 PM
04/05/13 12:55 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
My marine Sears die hard lived in my race-car for 7 years no alternator recharge after every round then lasted another 3 years in my trailer.But I tore up 3-4 starters every year & at least one flywheel per year using it,from kick back when starting the engine.Went to a 16 Volt have not had any engine kick back nor broke any starters.My Rock battery died this year after 3 years of service.After do as much research as I could it come down to either the 16 volt Rock or XS battery.I picked the Rock again because it has 1,050 CCA VS XS 675 CCA,The tech. @ Rock said it needed 12-15 mins between rounds to fully recharge,the tech. @ XS said their battery needed 25-30 mins. between rounds to fully recharge.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: viperakron]
#1414813
04/05/13 05:58 PM
04/05/13 05:58 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I get my batteries from my local CAT store.
Mopar to the bone!!!
[Re: 72Swinger]
#1414814
04/05/13 06:03 PM
04/05/13 06:03 PM
Guitar Jones
I have 2 Mopar batteries in my car... Might need that second one after the other one fails. But they've been there for 5 years now. I run a 90 amp alternator and use a battery tender when it sits. I never need to charge them at the track.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: viperakron]
#1414815
04/05/13 06:30 PM
04/05/13 06:30 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Optima is made in Mexico or China now. Not the same quality they started with.
Mexico...
Just my $0.02..
[Re: mopardude318]
#1414818
04/06/13 11:00 AM
04/06/13 11:00 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
If you don't run an alternator....I strongly suggest a drycell such as Odyssey
Rickster
Yes, the odyssey batteries are very good batteries...
The sears Die hard "Platinum" battery is the same exact thing as an Odyssey battery, only a 100 bucks cheaper....made in the same exact plant, same materials, same AGM technology, just with the sears platinum badging...
I have one in my mopar, and that is the best battery iv'e ever owned.
http://www.sears.com/diehard-platinum-automotive-battery-group-size-34-price/p-02850034000P
That is a great price....but I prefer the Odyssey PC1200MJT it's only 38lbs compared to 53lbs and the the posts are a better setup in my opinion $266.00
Rickster
[Re: viperakron]
#1414820
04/14/13 10:41 AM
04/14/13 10:41 AM
BradH
Really? I was going to replace mine that's been sitting dormant for the last 3 years (and assumed to have gone bad) w/ another one because I actually had good results with it. If they're not as good now as the original one I bought 5 years ago, that's too bad.
FWIW, my family's daily drivers all have either Interstate or Die Hards in them and the Interstates have generally lasted right about 5 years before needing replacement.
[Re: tboomer]
#1414822
04/14/13 10:55 AM
04/14/13 10:55 AM
BradH
Brad...They tried to sell me another Optima. I told him no thanks...I think the one he tried to sell me was like my old one...160.00!!
Yeah, I think the one I bought around 2007-2008 was close to $150, so that's not surprising.
[Re: babarracuda]
#1414825
04/14/13 11:18 AM
04/14/13 11:18 AM
Quicktree
I've had 3 Optima's. All had problems. I bought them at COSTCO and was able to return them. I bought an Autozne 750 CCA battery and no problems in 3 years. Car sits alot so I charge it after a long rest. I would not have another Optima even if it was free. Worst QC of anything I have bought EVER!!
you can't let any battery set with out a trickle charge. they will loose voltage every day.
[Re: babarracuda]
#1414826
04/15/13 08:47 AM
04/15/13 08:47 AM
Posts: 768 Fla
birdboy
Fla
save yourself a lot of bs and replace it with anything other than a optima.
the more I deal with people the more I like my dog
[Re: tboomer]
#1414828
04/15/13 03:20 PM
04/15/13 03:20 PM
72Swinger
Nebraska
You can get a 880cca industrial grade battery from your local Caterpiller dealer for around $105. They dont weigh anymore than an Optima either.
[Re: 72Swinger]
#1414829
04/15/13 06:49 PM
04/15/13 06:49 PM
Posts: 2,177 ill
dennismopar73
ill
My 2 cents,,, Optima is what I have had in my race car going on 4 years, no issue, I run 2 , with an alternator! Optima along with several other battery names have been made now by Johnson controls for @ 4 years now, All of Autozone are as well as Advances, and most of Orielys, Altho they do have some Excide batteries. All of Sears are Johnsons controls ,Walmart has a combo of excide, and Johnson control. Only a few batteries makes are made here in the USA, All of Johnson Controls are made either mexico, or china/japan! I believe the Excide Brothers may still be in jail?? Be that as it may, most batteries have a life of # 3 - 4 years! Acid or glass mate, or gel. batteries can be influence by alternators issues, or battery drain issues, the more the battery goes dead by improper wiring issues and such it takes life out of the battery, Improper charging technics is the biggest issue I have seen , use the correct charger for the type of battery you have
[Re: dennismopar73]
#1414830
04/15/13 07:52 PM
04/15/13 07:52 PM
Quicktree
there you have it, it's to easy to just blame the battery.
[Re: dennismopar73]
#1414832
04/15/13 11:49 PM
04/15/13 11:49 PM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
Johnson controls has several plants in the us that make batteries, at least 4-5 that I can think of.
68 Barracuda Formula S 340
[Re: dennismopar73]
#1414833
04/15/13 11:57 PM
04/15/13 11:57 PM
Posts: 1,238 Nevada
dezduster
Nevada
My first optima lasted me 12 years. I may have squeezed the last year out of it though. So I bought a new one and took a "bad" one that was offered to me from the store also. The "bad" one was 2 years old at the time. I charged the "BAD" one with my AGM charger and well one year later I have 2 good Optimas. I do believe there had been a quality control issue but not nearly as bad as people think.
